Reasons Why You Should Buy a Shark Apex Uplight Vacuum
Posted: Sun Nov 13, 2022 11:15 pm
Shark is always a brand specializing in the most famous vacuum cleaners today. Shark's models are always diverse in design, price, and product quality. You can choose a machine that suits your needs.
One of the most famous and highly praised vacuum cleaners by experts is the Shark apex uplight. Let's find out the reasons why you should own a Shark apex uplight in this post.
What Is the Shark Apex Uplight Vacuum Cleaner?
Check This Out: Shark Apex Uplight Vacuum - The Perfect Vacuum for Single People
First, we need to understand what the model is and what features it has. Previously, Shark produced both stick and upright vacuums, which were sold very successfully in the market. But gradually, customers began to feel that the design of these two models was not luxurious and the weight was somewhat heavier than other brands.
Understanding that, Shark launched the Uplight vacuum product line to serve customers. The Apex Uplight series is the perfect combination of a stick vacuum and an upright vacuum. Not only that, the latest and most advanced technologies are applied to this machine to improve the outstanding features of the vacuum cleaner.
If you have pets at home and are looking for a suitable vacuum cleaner for your home, the Shark Apex Uplight is the right choice. The machine can clean fur from the floor; dirt and bacteria will disappear, and no dust will be left.
Reasons Why You Should Own a Shark Apex Uplight Vacuum
1. Convert From Vertical To Lift-Away
The lift-away feature must be quite new for some people. This feature can be understood simply by using the vacuum cleaner in high places such as ceilings, and shelves.
To use this feature, you only need one light touch on the body of the Shark Apex Uplight Corded Lift Away. Then install the suction head and can use it easily.
In addition to high areas, the machine cleans hard-to-reach places in the house. You can even move the machine easily and clean the stairs in your home.
2. Huge Suction Power
Suction is always an issue that many people are interested in. Many customer’s Shark Apex Uplight review mentions that the machine’s suction power is very good. We can confirm that is true.
The suction power of the Shark Apex Uplight machine is very large, up to 700W. Compared to conventional vertical machines, this suction is still a bit low. But because this device is super-light, the suction power is quite impressive. With such suction, dirt, bacteria or even food particles will disappear.
3. It's Easy to Move
Shark's regular upright vacuum cleaner products often receive a lot of bad comments about their ability to keep their balance as well as their ability to move when in use. Such machines are often difficult to stand and move on carpets.
The special feature of Shark Apex Uplight is moving it in any position, even on high tassel carpets. When holding the vacuum cleaner upright, the wheels on the sides will automatically pop out, and you can use it easily.
4. HEPA Filters
Shark's vacuum cleaners are all equipped with HEPA filters to filter 99.9% of pathogenic bacteria from the air. And the Shark Apex is also equipped with this filter.
This feature can remove almost all bacteria and allergens from the air. In addition to cleaning dust, the machine will also improve the air quality in your home.
5. Duoclean Technology
In addition to the above features, Shark Apex Uplight Duoclean has a new, improved, special technology. It is the Duoclean self-cleaning technology.
In the suction head of the Shark machine, there are two types of cleaning brushes. There is a hard-bristled broom for cleaning carpets or carpeted stairs, and a soft-bristled brush will clean normal floor surfaces.
These two types of brushes, when combined together, will clean all kinds of surfaces. The combination of two types is a fairly common feature today. The machine will clean all large debris dropped on the carpet or small items on the floor.
In addition, because there are two types of brushes, the machine is capable of self-cleaning. If the machine picks up human hair or pet hair during use, you can easily remove them and continue to use the vacuum.
We recommend that you regularly clean both brushes after each use to ensure a longer machine life.
6. Simple Cleaning and Maintenance
After use, if you do not clean the machine regularly, the efficiency of the device will decrease. Many people will wonder how to make vacuum smell better. You must periodically wash the parts that directly contact dirt, such as filters, dust canisters, and sand suction nozzles, to maintain product quality.
Don't worry too much because the above parts are easy to disassemble and assemble. With just a few gentle lifts, the dust box can be disassembled and cleaned.
In addition, the preservation of the device is also something that we need to pay attention to so that the efficiency of the Shark machine does not decrease.
The machine is compact and extremely light in weight, making it very easy to store. Not only that, you just need to stand the vacuum cleaner upright, the two wheels of the machine will automatically pop out, and you can keep the vacuum cleaner in the corner of the room.
Check This Out: How To Make Vacuum Smell Better - Why Does My Vacuum Cleaner Smell Bad
7. Warranty Period
When you use your vacuum cleaner for a long time, it is inevitable to encounter some problems during use. Shark always pays attention to long-term product quality, so its products have a very long warranty period.
And the Shark apex uplight lift-away duoclean is no exception. The machine has a warranty period of up to 5 years. Such a long warranty period proves that the company is very confident in its products and always cares about customers.
FAQs
1. Where can the Shark Apex Uplight vacuum be used?
Shark apex uplight can be used on all floor types, from bare floors, hard floors to carpets. In particular, the lift-away feature helps you use the machine to clean cars, stairs, shelves, and ceilings.
Shark emphasizes that the Shark Apex Uplight works great on carpets or bare floors. These two locations are the places that regularly collect dirt and disease-causing bacteria in your home.
2. What is the difference between two types of Shark LZ601 and LZ602?
Shark LZ601 and LZ602 products are both the most typical products of the Apex Uplight series. The two types of machines do not have too many differences, and they are similar in size and weight. The salient features are also the same.
Both machines have good mobility, but the LZ601 is a bit more prominent. The cost of LZ602 is less than LZ601. So, if you are looking for an affordable product, the LZ602 is the perfect choice for you.
3. What points about the machine should we have to pay attention to?
Some things you need to consider before choosing to use this product:
Shark vacuum cleaner products always make people satisfied because of the product quality. We can confirm that the Shark Uplight Apex is one of the best vacuum cleaners available today.
Hopefully, through this article, you will consider using the Shark Apex Uplight vacuum cleaner and find the right model for yourself.
4. HEPA Filters
7. Warranty Period
FAQs
- Shark Apex Uplight is a corded vacuum cleaner, and the power cord is quite long.
- The dust box has a small capacity, and you must change it often to continue using it.
- It is a bit difficult to adjust the suction force of the machine.
