Which Steering Wheel?
Posted: Wed Nov 16, 2022 3:26 pm
by Gen3AntiqueAuto
I took the original one out years ago to make it easier to use the drivers door. Thinking I would be happier with a little more control so I'm considering a change. Which one should I put in the car, or keep the same?
https://youtube.com/shorts/Kep3hCOQKYc
Re: Which Steering Wheel?
Posted: Wed Nov 16, 2022 3:33 pm
by Jerry VanOoteghem
Honestly, none are "original" to the year of your T. I would definitely NOT use the little one.
Posted: Wed Nov 16, 2022 3:40 pm
by speedytinc
I use a large, aftermarket wheel on my 14 for the extra control.
Posted: Sun Nov 20, 2022 11:49 am
by Gen3AntiqueAuto
So the original steering wheel that came off the car is not original?!?
Jerry VanOoteghem wrote: ↑Wed Nov 16, 2022 3:33 pm
Posted: Sun Nov 20, 2022 1:25 pm
by RajoRacer
What year car did you remove the black wheel from ?
Posted: Sun Nov 20, 2022 2:13 pm
TheSpeedsterProject wrote: ↑Sun Nov 20, 2022 11:49 am
Your car appears to be a 26/27. I believe it should have the stamped steering wheel with the arms riveted to the hub, and not the cast steering wheel spider.
Posted: Wed Nov 23, 2022 1:59 pm
by Gen3AntiqueAuto
I'll take better photos when I do the swap so we can all see what we're looking at.
Posted: Wed Nov 23, 2022 2:34 pm
by Kerry
My Canadian 26 and 27x2 touring's have cast spiders
Posted: Wed Nov 23, 2022 3:22 pm
Kerry wrote: ↑Wed Nov 23, 2022 2:34 pm
Interesting! I'd be happy to be wrong if it turns out that's a legit thing. Maybe a Canadian variation?
Posted: Fri Nov 25, 2022 1:40 pm
by Gen3AntiqueAuto
Apparently this is cast as well - this was an original car from Canada when I bought it.
https://youtu.be/kiUOcWsBpJQ
Posted: Fri Nov 25, 2022 1:45 pm
by RajoRacer
Is it a 17" wheel ?
Posted: Sat Nov 26, 2022 9:57 am
by Gen3AntiqueAuto
I believe so - I used it as a template to make this one:
https://youtu.be/qEF5jDQDEgM
RajoRacer wrote: ↑Fri Nov 25, 2022 1:45 pm
Is it a 17" wheel ?
