Why a notch?
Topic author - Posts: 6496
- MTFCA Number: 16175
- MTFCI Number: 14758
Why a notch?
It must be there for a reason. What would that be?
- Last Name: Hunter
- Board Member Since: 2002
Re: Why a notch?
I always assumed it was to clear the key.
- First Name: Alan
- Last Name: Long
Re: Why a notch?
I’m with my Aussie Buddy from the other side of Australia but surely these were installed before the Key then the Hub?
Well that’s the way I’d do it?
Alan In Western Australia
- Last Name: Wrenn
- MTFCA Number: 30701
- MTFCI Number: 24033
Re: Why a notch?
Yep. Key clearance.
- Last Name: Wrenn
Re: Why a notch?
And there I go again...typing faster than my brain's in gear! I don't use those kind anymore, I like the "fancier" neoprene seals.
https://www.modeltford.com/item/2510N.aspx
- MTFCA Number: 121
- MTFCI Number: 16310
Re: Why a notch?
Apparently, few have installed those retainer caps. They go on just fine with the key in place.
Re: Why a notch?
Clearing the key was the only reason that occurred to me. So if that's the case there are two possible procedures that require the notch:
1 Install the washer, which has no notch, then the felt, which has no notch, then the key, and finally the cap, using the notch to get it past the key.
2 Remove the cap, using the notch to get it past the key, then remove the key, and then the felt, and then the washer.
How are those procedures better than installing or removing all three parts without the key in place?
- Last Name: Hjortnaes
- MTFCA Number: 28762
- MTFCI Number: 22402
Re: Why a notch?
I agree with Tim. Use the new style. The old style never wants to come off anyway.
- First Name: Joseph
- Last Name: M
- MTFCA Number: 0
Re: Why a notch?
I used to agree with that statement, then I found the right tool for the job:
- First Name: Jim
- Last Name: Riedy
- MTFCA Number: 25079
- MTFCI Number: 18732
Re: Why a notch?
Well La Dee Da Now I have a new tool to look for. Thanks Pep
- Last Name: C
- MTFCA Number: 52098
Re: Why a notch?
It would be great to see the inside of the tool when possible.
Socialism is resentment disguised as compassion enforced by tyranny disguised as tolerance.
- MTFCA Number: 28924
Re: Why a notch?
I never thought about what the notch was for. I saw the notch and figured it ought to be lined up with the key way. When removing the cover I tapped around the outside with a ball pain hammer. That would usually loosen it enough to get it to move and then spray behind it with WD40. It would then slip off.
I wooden if Stevens made a tool to use for it. They made one for most other T parts. If they did it’s not common. And if the one pictured or presumably a Stevens tool was found in a box of this and that at a swap meet it was probably passed over because it wasnt recognized.
- Last Name: M
- MTFCA Number: 0
Re: Why a notch?
Not to hijack the thread (too much), I will add a link to a previous post with some more photos of the Dust Cap Puller.
viewtopic.php?f=2&t=9483&p=70586&hilit=cantrell#p70586
It was one of the axle tools made by Cantrell-Miller, I am fortunate enough to have all (both T and TT sleeve pullers) the tools shown, except the Hub Puller and Waste Puller that are pictured below.
- Last Name: C
Re: Why a notch?
Totally related if you ask me! Thanks for the extra info.
