Ruxtel and Rocky Mountains
Don ellis
First Name: Don
Last Name: Ellis
* REQUIRED* Type and Year of Model Ts owned: 1911,1917,23,27
MTFCA Number: 17946
MTFCI Number: 15366
Post by Don ellis » Fri Nov 25, 2022 12:21 pm
I’m sure there’s a way to run both but my shifter is hitting the rocky linkage from the brake pedal. Do I have to run the hand brake shifter or something?
Fire_chief
First Name: Charlie
Last Name: Gagel
* REQUIRED* Type and Year of Model Ts owned: 12 Tourings(2),14 Tourings(2),15 Touring,22Touring,22 TT,21 Fire Truck,14 Chief Car
MTFCA Number: 8377
MTFCI Number: 22437
Re: Ruxtel and Rocky Mountains
Post by Fire_chief » Fri Nov 25, 2022 12:24 pm
Try turning the shifter around so the spring is on the other side.
First Name: john
Last Name: karvaly
MTFCA Number: 14383
Post by speedytinc » Fri Nov 25, 2022 12:33 pm
Your shifter is mounted backwards.
Post by Scott_Conger » Fri Nov 25, 2022 12:36 pm
NH Full Flow Float Valves
Don ellis
First Name: Don
Last Name: Ellis
MTFCA Number: 17946
MTFCI Number: 15366
Post by Don ellis » Fri Nov 25, 2022 12:37 pm
Sometimes you can’t see the forest for the trees, thanks
MTFCA Number: 121
MTFCI Number: 16310
Post by Original Smith » Sat Nov 26, 2022 2:06 pm
One thing few folks know about Ruckstells, is when Eaton took over production from Hall Scott, they changed the design of the patent plate, to the clipped corner design which some people think is the 1926-7 design. Yes, it is, but it is really the Eaton design, and they made small drum models too with the clipped patent plate. I have one of those housings on my 1925.
