Timken front wheel bearings
Posted: Fri Nov 25, 2022 7:02 pm
by Algonac27
Would anyone have the Timken numbers for outer and inner front bearings.
Re: Timken
Posted: Fri Nov 25, 2022 7:37 pm
by CudaMan
A Google search for "timken front wheel bearings mtfca" revealed this older thread:
http://www.mtfca.com/discus/messages/70 ... 1511123413
Re: Timken
Posted: Fri Nov 25, 2022 7:41 pm
by Jeepbone1
Here you go.
Brad
Re: Timken
Posted: Fri Nov 25, 2022 10:34 pm
Rock auto usually has the best prices on those, IF they're in stock.
Re: Timken
Posted: Fri Nov 25, 2022 10:37 pm
by Algonac27
Thanks guys!!!
Re: Timken
Posted: Sat Nov 26, 2022 10:14 am
by TWrenn
It's been so long since I've heard from Rock Auto, but if my lame brain is correct, I"m STILL waiting for the inside left bearing...or maybe it was the right side, or even both! Ha ha. Point is, they're mostly unobtanium for some stupid reason. :evil:
Re: Timken
Posted: Sat Nov 26, 2022 11:15 am
Rock Auto prices & availability TIMKEN 09075 doesn't look it is available anywhere but some sites indicate end of this year or January 2023
Re: Timken
Posted: Sat Nov 26, 2022 7:18 pm
Tim, it's the outer bearing that is out of stock. I have right hand bearing on back order with Langs, and no indication of availability. They have the left ones.
Re: Timken
Posted: Sat Nov 26, 2022 7:30 pm
by DHort
Rock Auto will notify you when 9075 is available. However, they have had to renew my request 2-3X because my request has been in their system so long. If I hear anything I will post it on here, but dont hold your breath. If I knew anyone at Timken I would ask. Might still be due to pandemic and supply issues.
Re: Timken
Posted: Sun Nov 27, 2022 12:02 am
by Nv Bob
Amazon beat rock auto and if you have prime free shipping
Get all except the threaded outer bearing
Re: Timken
Posted: Sun Nov 27, 2022 1:32 am
I did a comparison for TIMKEN 09194 - plus shipping,
NOTE if you select AMAZON as the sellers shipping requires an order of $25 or more.
So the number of items being purchased from the same supplier needs to be considered for a shipping total
For this 1 item TIMKEN 09194 with shipping the least expensive was RockAuto, next eBay or Amazon (depends on which offer you select and if you have Prime)
Re: Timken
Posted: Sun Nov 27, 2022 8:56 am
by TWrenn
Thanks Allen! I've been so busy, causing me to be remiss in staying on it. I'll order a couple today!
Re: Timken
Posted: Sun Nov 27, 2022 1:47 pm
by DHort
Tim,
I thought you needed bearings. If you order races, you will be sadly disappointed. They are not interchangable.
9075 is the only item not available. This has been a problem for at least a year.
Posted: Tue Dec 06, 2022 12:50 pm
by ChrisB
Back in stock, got mine today.
Re: Timken front wheel bearings
Posted: Tue Dec 06, 2022 5:12 pm
Who has them Chris? Better PM me so all the lurkers here don't jump the queue. :D :D
Posted: Tue Dec 06, 2022 5:49 pm
Just looked RockAuto
Posted: Tue Dec 06, 2022 11:03 pm
by ChrisB
Yes got mine from Rock Auto.
Posted: Wed Dec 07, 2022 11:49 am
by DHort
Mine are ordered and arriving next week.
Posted: Wed Aug 23, 2023 2:08 pm
by ChrisB
Anyone had any problems with the new supply?
I tried to install one today and it will not screw on all the way, it's like when you mix a close metric thread to a SAE one.
I tried it on 2 different spindles and also tried both bearings with the same result.
Chris
PS as mentioned above it is the left bearing with the regular threads 09075
Posted: Wed Aug 23, 2023 2:48 pm
by AZTerry
I have seen this problem several times in the past. I take a thread file to the spindle to clean up the threads. A helical wire brush on the inside threads of the bearing may help as well.
Terry
