How Tight Should These Nuts Be
Topic author - Posts: 878
- First Name: Bruce
- Last Name: Brakke
- MTFCA Number: 31192
How tight should these nuts be? Is there recommended torque value?
1) Spring shackle nuts.
2) Nuts on bolts attaching front and rear springs to the frame.
- First Name: Mike
- Last Name: Cushway
- * REQUIRED* Type and Year of Model Ts owned: 1925 TT, 1926 TT, 1926 TT
- MTFCA Number: 52588
Re: How Tight Should These Nuts Be
Hand Wrench tight and cotter.
- First Name: Joe
- Last Name: Bell
- MTFCI Number: 24066
snug, get all the weight of car and body then check them, they will draw up more then, do not have to he man them they are just there to hold all in place.
- Last Name: Patrick
- MTFCA Number: 50126
Does this help? I copied it from a Dec. 31, 2007 MTFCA thread. I believe I read on the forum that they did not use torques during the Model T era. Experienced mechanics just tightened by feel. Torque charts came about years later to show how tight certain sized bolts could be safely tightened before stripping or breaking. Jim Patrick
- MTFCA Number: 16175
- MTFCI Number: 14758
"Tighten it until just before it breaks."
- Last Name: Bartsch
- MTFCA Number: 30615
I agree with Mike on spring shackles, but spring to frame clamps, I tighten same torque as rear axle hub nuts. And cotter everything before you test drive. Spring to frame clamps may need retorquing after test drive. jb
- First Name: Art
- Last Name: Ebeling
- * REQUIRED* Type and Year of Model Ts owned: 1911 touring 14 runabout
- MTFCA Number: 50718
I usually tighten most bolts until they break and then back them off a quarter turn. Art
- MTFCA Number: 51486
The spring to frame clamp nuts need to be tightened evenly in a cross pattern with the car sitting on level ground. After running a hundred miles or so, they will most likely need retightening. With old parts, caution must be used. For best results, have parts clean and springs lubricated.
- Last Name: Gould
Spring shackle nuts should be kept loose enough to allow movement.
Spring shackles as an assembly should be 'tight', if they bind on either the spring or perch that issue needs to be corrected in a way that permits full and tight assembly of the shackles. Shackle bolts left loose promote rapid wear of both the shackles and spring/perch bushings. jb
