Museum Hours Pop-Up
Posted: Wed Jan 04, 2023 1:55 pm
Suppose the powers at be might be able to disable the pop-up regarding museum hours please, now that the time of notice is long past ?
Thanks !
Re: Museum Hours Pop-Up
Posted: Wed Jan 04, 2023 3:52 pm
by modeltspaz
I'd like to second that motion, if I may.
Posted: Wed Jan 04, 2023 8:52 pm
by Petrah Phyre
All those in favor...
Posted: Wed Jan 04, 2023 10:15 pm
by ChrisB
... passed.
Removed.
Chris
Posted: Wed Jan 04, 2023 10:47 pm
I thank you kindly, Sir !
Posted: Sun Jan 08, 2023 8:18 am
by J1MGOLDEN
Your problem is you do not understand the purpose of another memory section in your computer.
The purpose of which is to keep items often used right in your computer to save time downloading that information several times.
Posted: Sun Jan 08, 2023 8:24 am
by J1MGOLDEN
From Wikipedia, the free encyclopedia
In computing, a cache is a hardware or software component that stores data so that future requests for that data can be served faster; the data stored in a cache might be the result of an earlier computation or a copy of data stored elsewhere. A cache hit occurs when the requested data can be found in a cache, while a cache miss occurs when it cannot. Cache hits are served by reading data from the cache, which is faster than recomputing a result or reading from a slower data store; thus, the more requests that can be served from the cache, the faster the system performs.
To be cost-effective and to enable efficient use of data, caches must be relatively small. Nevertheless, caches have proven themselves in many areas of computing, because typical computer applications access data with a high degree of locality of reference. Such access patterns exhibit temporal locality, where data is requested that has been recently requested already, and spatial locality, where data is requested that is stored physically close to data that has already been requested.
