1919-22 Coupe Photos
Posted: Mon Jan 09, 2023 9:58 am
by Tadpole
Hope everyone's having a fine Monday. I am looking for some photos of the space under the seat cushion on 1919-22 suicide door coupes. How much space should be there? Is it a storage compartment or is it somewhat useless?
And if you got a suicide door coupe you are proud of, share photos of the whole machine if you'd like. Now all of them are at least 100 years old.
Re: 1919-22 Coupe Photos
Posted: Mon Jan 09, 2023 10:37 am
by MWalker
FYI, 1923 Coupes are the same bodies as 19-22's.
Posted: Mon Jan 09, 2023 11:44 am
by Rich Eagle
These are some I took of mine. I believe it is close to correct.
Posted: Mon Jan 09, 2023 12:26 pm
by M.Sinclair
Here is the frame they have at piquette.
Posted: Mon Jan 09, 2023 1:47 pm
by Tadpole
Thank you much for the photos, from what I can see the space under the seat is negligible.
Posted: Mon Jan 09, 2023 2:15 pm
by Rich Eagle
It's about the same as this coupelet.
Posted: Mon Jan 09, 2023 3:12 pm
by Tadpole
Thank you kindly Rich, that is very helpful. Maybe one could make a drop floor to increase the area of the compartment? Maybe not with the driveshaft there? I will do some more research and testing.
Posted: Mon Jan 09, 2023 3:38 pm
by Rich Eagle
There is a metal panel for the bottom. Mine had been cut for such a purpose. There is some room above the drive shaft or more on each side if you choose.
