Tappet Clearance
Posted: Mon Jan 16, 2023 7:38 pm
by johnr
Rebuilding a spare engine and found on inspection that I am going to need to go to
oversize tappets .
What is the recommended clearance between the tappet stem and the valve
guide ?
Thank you.
Re: Tappet Clearance
Posted: Mon Jan 16, 2023 7:43 pm
by Kerry
That will depend on what valves, original or new replacement.
Posted: Mon Jan 16, 2023 8:09 pm
by Craig Leach
Hi John,
Most of the suppliers sell a piloted reamer for the oversized tappets. I have found them to be a perfect fit. They are a little pricy
check with people you know they may have one. Or be in need and willing to share the cost.
Craig.
Posted: Tue Jan 17, 2023 1:22 pm
by Art M
I have a reamer. I can come to your house and do the job. I am only 5 miles away.
Art Mirtes
Posted: Tue Jan 17, 2023 1:32 pm
by Moxie26
....":::.…. Ooops
Posted: Tue Jan 17, 2023 1:53 pm
by Art M
It is Art from Huron, Ohio who has the reamer and it is John from Huron, Ohio who needs a reamer. Many many miles from Arizona..
Posted: Tue Jan 17, 2023 3:03 pm
by Kerry
Oops! after re reading your question, the difference in terminology from each end of the world :o tappet clearance would be the lash, but what you are asking is push rod clearance correct? Well Ford specs are STD diameter is .4355", to .4365" and push rod guide holes are .437" The 2 over size push rods are .015" and .030" OS.
Posted: Tue Jan 17, 2023 7:47 pm
by Art M
John, you have my condolences on the loss of your mother which was shown in the local paper. I used to work with your brother Ti. He was well organized.
Art Mirtes
Posted: Fri Jan 20, 2023 4:21 pm
by johnr
Art
Sent you several messages thru the forum.
I can be reached at roswellplastic@aol.com
Thank you
Johnr
Posted: Fri Jan 20, 2023 5:44 pm
by Art M
John, I hope to call you soon for a visit. Sorry about not responding quicker.
Art Mirtes
