Windows
Posted: Thu Jan 19, 2023 12:38 pm
by Barteldes
I have a cracked Drivers side window and need to replace both windshields. I have a 1924 Coup. How or where.. do i go to get this glass?
Re: Windows
Posted: Thu Jan 19, 2023 12:56 pm
by jsaylor
Local Auto Glass shop. Take the old for a pattern.
Re: Windows
Posted: Thu Jan 19, 2023 1:34 pm
When you go to the glass shop make sure they know that the Coupe windows are not square!
If they know what they are doing they will use your window as a pattern. Don’t assume that they do. Of course they probably will but don’t forget that they may not know about the window. Some don’t!!
Re: Windows
Posted: Thu Jan 19, 2023 2:12 pm
by Barteldes
Great ! thanks you guys!
Re: Windows
Posted: Fri Jan 20, 2023 9:47 am
by jab35
Also check the thickness of the new glass. Not all glass shops carry safety glass in same thickness as original glass. Different replacement glass thickness will require different windshield bedding hardware and different sliding channel configuration for 'moveable' glass. just FYI, jb
Re: Windows
Posted: Mon Jan 23, 2023 9:44 am
by Barteldes
Having trouble finding a glass shop in the Denver area that wants to play with auto glass. Does anyone know of a shop that will accomodate?
Re: Windows
Posted: Mon Jan 23, 2023 9:51 am
There may be a classic car or old car restoration shop that does rebuilds in your area. Check to see if there is one close to you. They have their glass cut or installed somewhere or do it themselves. They may be of help.
Re: Windows
Posted: Thu Jan 26, 2023 9:40 am
by Barteldes
I found one in Denver Edgewater Glass
Re: Windows
Posted: Thu Jan 26, 2023 1:31 pm
by CudaMan
Here are the glass dimensions in case the glass shop can't or won't use your old glass for patterns.
Re: Windows
Posted: Sun Jan 29, 2023 11:12 am
by Barteldes
Awsome thanks!
Re: Windows
Posted: Sun Jan 29, 2023 2:07 pm
by A Whiteman
Not sure how it works in the US, here in New Zealand a local general glazier made the screens up then sent them out to be hardened, they came back with 'safety glass' markings and all ready to go.
General glaziers do safety glass regularly for architectural features, houses, fences etc so this is not unusual work for them and they are used to working off templates/ patterns.
Safety glass can only be cut before it is hardened, else it shatters.....
Re: Windows
Posted: Sun Jan 29, 2023 3:34 pm
by Russ T Fender
I believe that in modern cars the side windows are tempered glass but the windshields are laminated safety glass. I just replaced the glass in my 1930 Plymouth with laminated safety glass all around. It was hard to find someone who will work with that stuff these days but they are out there.
