Button on the dash
Posted: Mon Jan 30, 2023 11:41 am
by Barteldes
24 Model T Coupe: There is a button to the left of the steering wheel on the dashboard. Any thoughts of what it does? I hope i can attach a picture.
Re: Button on the dash
Posted: Mon Jan 30, 2023 11:53 am
by Humblej
Looks like a light switch.
Posted: Mon Jan 30, 2023 11:55 am
Its a push/pull light switch 1915 - 1917 . was mounted to the right of coil boxes on the dash(firewall). It might be used form some other function
Posted: Mon Jan 30, 2023 12:57 pm
by Barteldes
Thanks you guys ... im new at this but not afraid to ask questions. So much knowledge here in this chat!
Posted: Mon Jan 30, 2023 1:05 pm
by Rich Eagle
It might have been for a spotlight. I have used switches on the dash to cut power to the generator when cutouts were faulty. It obviously was added at some time after production.
I'm glad for those not afraid to ask.
Posted: Mon Jan 30, 2023 1:23 pm
Is it just the switch, or are there wires you can follow?
Posted: Mon Jan 30, 2023 2:12 pm
See if you can see any screw holes on the side of the door posts. There may have a spotlight or something like it mounted years ago.
But put you hand under the dash and see if there are wires on the backside of the switch. Maybe you can wiggle or pull them a little and have someone look under the hood where the wiring block is. That’s probably where any wires would have been. That switch is located on the same side of the car as the wiring block is.
Posted: Mon Jan 30, 2023 2:20 pm
by ThreePedalTapDancer
Be careful until you trace the wires, an ex fighter pilot may have owned the car..
Posted: Mon Jan 30, 2023 2:38 pm
I would expect a wire from the terminal block to the switch, and another from the switch to whatever accessory it's for. If the accessory is gone, that second wire might lead to its location and suggest what it was.
Posted: Mon Jan 30, 2023 5:03 pm
by Barteldes
God i love you guys!
