Drop front axle tie rod & drag link issue
Posted: Tue Jan 31, 2023 8:20 pm
by Roger Byrne
Has any one done a speedster front suspension using a 2" drop front axle, with the early style perches, a double wishbone (above and below the axle) mounted to the engine pan (not on the outside of the frame), reverse eye spring and 26-27 spindles? If so, how did you set-up the tie rod and drag link?
