Battery ground
Topic author - Posts: 81
- First Name: Bill
- Last Name: Barteldes
- * REQUIRED* Type and Year of Model Ts owned: 1924 Coup
Battery ground
Are Model T's supposed to be positive ground?
BIll B
No matter how you shake and dance the last few drops go down your pants.
- MTFCA Number: 14972
- MTFCI Number: 15411
Re: Battery ground
No - negative ground - Model A started with positive ground.
- Last Name: Jablonski
- MTFCA Number: 407
Re: Battery ground
If your Model T was running on positive ground, I'm sure your ammeter shows discharge instead of charge while running. Reverse the battery terminals to negative ground and before starting just connect the output of your cutout to the Post connection on the generator very briefly to polarize generator , this way the generator will be charging properly.
Re: Battery ground
The correct answer as stated is they are negative ground. It would help to understand the basis of the question before responding to suggestions.
- MTFCA Number: 14383
Re: Battery ground
After you get the wiring correct, Your first running may show a dead generator requiring re-polarization.
