So my 26 Touring has nickel windshield stanchions that are not on the car. In looking where they go one side of the body has three holes like the stanchion the other has two. I looked on the back side of the metal and could not see any evidence of a third hole that may have been filled in. The car did not have the windshield in it when I got it. Should it be drilled?
Also looking at how the steering column is installed I noticed a hole in the dash that is covered up is this how the steering column supposed to be attached? The previous owner used the wrong head screws.
Any help would be appreciated. Thanks!!
26 touring Help with the windshield
- First Name: Eric
- Last Name: Macleod
- * REQUIRED* Type and Year of Model Ts owned: 13 Touring, 24 Touring, 26 Fordor, 27 Fordor, 27 Touring, '92 Stynoski, '06 Stynoski owner emeritus
- MTFCA Number: 50125
- MTFCI Number: 19464
Re: 26 touring Help with the windshield
Here is what it is supposed to look like. I think you have too many steering column holes and not enough for your winshield stantions. Also, your stantions should be painted black. Hope thi
s helps.
1913 Touring
1926 Fordor
1926 Touring
1927 Touring
Stynoski 2006, Nash, Franklin, Lincoln, Cadillac and Buick owner emeritus
1926 Fordor
1926 Touring
1927 Touring
- First Name: DEAN
- Last Name: YODER
- * REQUIRED* Type and Year of Model Ts owned: 19tour,24tour,25rdpu,27rd.26coupe,TT's,& tractor conversions
- MTFCA Number: 295
- MTFCI Number: 127
Wind shield stanshions have 3 holes.
Steering column has 4. Bottom brackets in photo
Here is what the body looked like when I purchased it. The brackets fit here
You can see the holes drilled for the windshield posts and also the windshield posts bolted on. The only bracket inside is the one under the steering column. That bracket over the steering column on your car is from some other model.Norm
Topic author - Posts: 1093
- Last Name: Govoni
- MTFCA Number: 32331
Thanks for the pictures. I wonder what year bracket is on my car? If the guy before me drilled the dash then I won't feel bad drilling it for a clock later. Makes me also wonder why there is no third hole???
- First Name: Eric
If i were to guess, when you get it apart you will find a patch on the back side. Go ahead and drill a new hole.
1913 Touring
1926 Fordor
1926 Touring
1927 Touring
1926 Fordor
1926 Touring
1927 Touring
