Rocky Mtn brakes
Posted: Mon Mar 06, 2023 11:35 pm
Looking at the pictures of a set for sale and I have questions.
Does the yoke with the rods attach to the hand brake cross shift. When applying is the short double clevis rod hooked to the yoke and the extension on the brake pedal and thereby causing the yoke to rock and pull on the brake rods or is the clevis attached above the brake pedal shift and pulling on the yoke causing it to rock and pull or push the rods?
