1915 top bow mystery marking
Posted: Sun May 05, 2019 8:57 pm
by NealW
This weekend I removed the old top and bow wrapping on my 1915 runabout restoration project. The bows had what appeared to be original wrapping, and I felt like I was unwrapping an old Egyptian mummy. The front bow wood had "30 lbs" marked on it. Does anyone know if Ford, or whomever made the top bows for him in 1915, use recycled wood for the bows? The marking doesn't make any sense, and the other bows do not have any markings on them.
Thanks,
Neal
Re: 1915 top bow mystery marking
Posted: Mon May 06, 2019 4:46 pm
Seems unlike a Ford top bow, wood seems thin and narrow. Perhaps was some other use prior to being placed into a top iron, but can't see the ends to be sure that is a tapered wood bow. Front bows always took a beating, and maybe someone added that piece as a stiffener?
Early style, with wood bows that are steam bent and are tapered at the ends to fit down into the metal oval irons.
Posted: Mon May 06, 2019 9:36 pm
by NealW
The picture makes it look thinner than it is. It is steam bent, and appears to have the same overall dimensions as the other wood bows. If someone did make a replacement, they did a good job. Overall the wood looks as ancient as on the other two bows.
Neal
Posted: Mon May 06, 2019 9:49 pm
by Ruxstel24
Maybe part of one of the packing boxes Henry was said to reuse ?
Posted: Tue May 07, 2019 8:07 pm
If by "unwrapping an Egyptian mummy" you mean that the covered was wound around the bow in a spiraling manner, then it was not original covering and perhaps then, not an original bow.
Posted: Tue May 07, 2019 9:24 pm
by NealW
No, it wasn't wound around the bow. The fabric just look old, like you would see on an Egyptian mummy! The fabric on all the bows was attached the same, and looked similarly old. The middle bow had been wrapped with black fabric years ago when a new top was put on. That top was also old, my guess 50+ years.
Neal
