Starter amperage draw?
Topic author - Posts: 1315
- First Name: Robert
- Last Name: Jablonski
- MTFCA Number: 407
What would be the average acceptable amperage draw on a Model T starter?
Re: Starter amperage draw?
Assuming one that is in correct working order
Free running with no load: 70 amps/5.5 volts/4000 RPM.
Cranking engine: 150-160 amps/5 volts/150 RPM
Stalled torque test: 450 amps/3-4 volts/12 foot pounds torque.
- MTFCA Number: 407
Thank you Frank
- First Name: Luke
- Last Name: P
In case anyone wants to print out Frank's sheet this may assist:
