Leaks Between Spark Plugs & Head
David Tipton
First Name: David
Last Name: Tipton
MTFCA Number: 31392
MTFCI Number: 23748
Post by David Tipton » Wed May 08, 2019 9:55 am
I have a 1915 Touring with the original head. I had the motor and transmission rebuilt about 4 years, alum. pistons, scat crank, stainless valves & seats, etc. Yesterday when I drained and refilled the radiator some accidentally splashed into the 1st and 2nd spark plug dimples on the head. When I started to crank the motor I saw bubbling around the spark plug threads, I tightened the plugs as much as possible but to bubbling is still there. This is happening around all 4 plugs even after tightening. I don't think this is a new problem I happen to notice it because I splashed coolant on the head while refilling.
The plugs are new Champion 25's. I would appreciate all suggestions/help.
Thanks,
David Tipton
Colleyville, TX
Charlie B in N.J.
First Name: CHARLIE
Last Name: BRANCA
MTFCA Number: 28967
Board Member Since: 2010
Re: Leaks Between Spark Plugs & Head
Post by Charlie B in N.J. » Wed May 08, 2019 9:58 am
Actually kind of common. You'll hear everything from Teflon tape (white & Yellow) to tin foil on the threads. Yellow Teflon is my choice.
MTFCA Number: 16175
MTFCI Number: 14758
Post by Steve Jelf » Wed May 08, 2019 10:18 am
It's a problem only if it lowers compression or if you let a lot of water leak into the cylinders, but foil or Teflon tape are OK. Some are afraid the tape will unground the plugs, but the threads will cut through it and contact the head.
George N Lake Ozark
First Name: George P
Last Name: Clipner
MTFCI Number: 18665
Post by George N Lake Ozark » Wed May 08, 2019 5:19 pm
I had the same issue on my Z Head. I have used tin foil but had issues removing the plugs. I use anti seize now and no issues. A few years back, Champion made some new X's with bad threads that would leak. The new ones I'm running don't have that issue but did have seepage on the Z Head. Anti seize works for me.
kirkiep
First Name: Kirk
Last Name: Peterson
MTFCA Number: 24051
MTFCI Number: 141
Post by kirkiep » Wed May 08, 2019 7:00 pm
George
Anti seize works good for me too.
Kirk Peterson
Santa Fe NM
David Tipton
First Name: David
Last Name: Tipton
MTFCA Number: 31392
MTFCI Number: 23748
Post by David Tipton » Wed May 08, 2019 7:50 pm
Any particular brand of Anti Seize?
Thanks,
Dave Tipton
David Tipton
First Name: David
Last Name: Tipton
MTFCA Number: 31392
MTFCI Number: 23748
Post by David Tipton » Wed May 08, 2019 7:52 pm
George
Thanks for your recommendation of using Anti Seize, any brand in particular?
David Tipton
kirkiep
First Name: Kirk
Last Name: Peterson
MTFCA Number: 24051
MTFCI Number: 141
Post by kirkiep » Thu May 09, 2019 9:51 am
What ever the Parts store has in stock.
Kirk Peterson
Santa Fe NM
hah
First Name: john
Last Name: hardiman
Post by hah » Thu May 09, 2019 10:00 am
Cooper.... takes the heat...use it on engines I have rebuilt ..non t.
Last Name: Gregush
Post by Mark Gregush » Thu May 09, 2019 10:39 am
I use ether anti-seize or white teflon tape, which ever I have at hand at the time. I have some old anti-seize with lead in it (known in California to cause all kinds of nasty things to the body if you eat it! :lol: ), but as said above what ever brand.
1921 Huckster
