Kingston L2 Float
Posted: Mon Apr 17, 2023 4:50 pm
Got another carb question. The (hopefully) attached image is an inverted view of the Kingston L2 off my 1917 Touring. Inverted, so that's how the float sits when full of fuel and closed. The inside opening of the float doesn't fit around the carb body. It hits the card body, not allowing adjustment of the float tang to bring the float even with the gasket surface.
My first thought is that it's just the incorrect float, and that I need to get the right one. My second thought is that I can extend the hinge to raise what would be the right side of the float (in the picture), and move it more to the left (in the picture) allowing it to clear the carb body for a better closed angle and better drop. Any thoughts? Or did Kingston make what may be the only guys on the planet to hang the float at such a dumb angle.
Thanks in advance, Maury Dean
