Burnishing?
BobShirleyAtlantaTx
First Name: Bob
Last Name: Shirley
MTFCA Number: 29135
Burnishing?
Post by BobShirleyAtlantaTx » Thu May 09, 2019 10:08 am
Please show the set-up you use to run your shaft in.
Last Name: Gregush
MTFCA Number: 52564
Re: Burnishing?
Post by Mark Gregush » Thu May 09, 2019 10:35 am
I blue/scrape any high spots and use Timesaver to set my rods and crank.
1920 Dodge touring
D.Yoder
First Name: DEAN
Last Name: YODER
* REQUIRED* Type and Year of Model Ts owned: 19tour,24tour,25rdpu,27rd.26coupe,TT's,& tractor conversions
MTFCA Number: 295
MTFCI Number: 127
Re: Burnishing?
Post by D.Yoder » Thu May 09, 2019 10:40 am
Timesaver run in
Timesaver run in
Mark Osterman
Last Name: Osterman
Re: Burnishing?
Post by Mark Osterman » Thu May 09, 2019 10:48 am
I know what you mean by using the word burnishing for this but if there is an abrasive being used .. it’s something else. Even though the abrasive is fine you are grinding. I use burnishing two ways in my day job; gold leaf and putting a glossy surface on albumen photographic prints. In both cases the object to be burnished is rubbed with a tool only to make the surface smoother.
Ruxstel24
Last Name: Hanlon
MTFCA Number: 50191
Re: Burnishing?
Post by Ruxstel24 » Thu May 09, 2019 10:58 am
Burnishing to me means "heat"...
I recall the term mostly in automatic transmission clutch plates. Some rebuilders will slip the clutches purposely, after a rebuild to smooth out the clutches. Supposedly this helps with smoother shifts/clutch application.
Not a big believer myself.
Torque converter lock-up clutches on some vehicles, had a break-in procedure that was activated through the computer to basically slip the clutch for a couple hundred miles after replacing a converter.
Adam
First Name: Adam
Last Name: Doleshal
MTFCA Number: 23809
MTFCI Number: 1
Re: Burnishing?
Post by Adam » Thu May 09, 2019 11:14 am
Burnishing or running in is not necessary if the surface finish and dimensional tolerances of the crankshaft and main bearings is good.
“Running In” as Ford specified was to correct the fits and tolerances in case the machining was sloppy. In most cases it was. The act of “liberally oiling the bearings and running in the mains until the bearings smoke” was to provide a fairly precise fit without high precision measuring, without high precision machining, and with only a moderately skilled mechanic doing the work. The temperature that the oil smokes at is the temperature that the journal has expanded enough to provide proper oil clearance once everything has cooled.
HornsRus
First Name: Charley
Last Name: Shaver
* REQUIRED* Type and Year of Model Ts owned: 1913
Re: Burnishing?
Post by HornsRus » Thu May 09, 2019 12:16 pm
i guess i could use this!!!!!!!!!charley
D.Yoder
First Name: DEAN
Last Name: YODER
MTFCA Number: 295
MTFCI Number: 127
Re: Burnishing?
Post by D.Yoder » Thu May 09, 2019 6:43 pm
Charley I like it more pictures please :D
HornsRus
First Name: Charley
Last Name: Shaver
Re: Burnishing?
Post by HornsRus » Thu May 09, 2019 6:56 pm
ok.charley
motor stand.jpg (20.71 KiB) Viewed 7394 times
Adam
First Name: Adam
Last Name: Doleshal
MTFCA Number: 23809
MTFCI Number: 1
Re: Burnishing?
Post by Adam » Thu May 09, 2019 8:35 pm
Where is it? It needs to go to the Model T Museum!
HornsRus
First Name: Charley
Last Name: Shaver
Re: Burnishing?
Post by HornsRus » Thu May 09, 2019 9:56 pm
don't worry about it it is in my museum.ha ha. charley
JWalters
First Name: Jason
Last Name: Walters
* REQUIRED* Type and Year of Model Ts owned: 1922 Touring
Re: Burnishing?
Post by JWalters » Fri May 10, 2019 12:50 am
It's just waiting for Charley to decide to scrap it. :roll: What a shame.
Jason Walters
Last Name: Hatch
MTFCA Number: 49974
Re: Burnishing?
Post by Dan Hatch » Fri May 10, 2019 6:54 am
Charley: Email went. Thanks, Dan
HornsRus
First Name: Charley
Last Name: Shaver
Re: Burnishing?
Post by HornsRus » Fri May 10, 2019 7:15 am
scrap maybe not,as i have been offered $5000.00 for it.oh looks like sandblast and go to work. charley
Kerry
Last Name: van Ekeren
Re: Burnishing?
Post by Kerry » Fri May 10, 2019 8:13 am
How is it driven? is it flat belt on the drum or are the inturnals of the drum an electric motor?
This diagram shows the complete engine has a fuel line, is the engine being driven or for driving?
HornsRus
First Name: Charley
Last Name: Shaver
Re: Burnishing?
Post by HornsRus » Fri May 10, 2019 10:08 am
it is run off line shaft,but motor can do the work, also motor can be started with it. charley
Adam
First Name: Adam
Last Name: Doleshal
MTFCA Number: 23809
MTFCI Number: 1
Re: Burnishing?
Post by Adam » Fri May 10, 2019 10:41 am
If the engine was driving the crank in the bare block as shown in the picture, it would be turning the crankshaft in the wrong direction.
HornsRus
First Name: Charley
Last Name: Shaver
Re: Burnishing?
Post by HornsRus » Fri May 10, 2019 11:32 am
do you think it would matter??????????? charley
Kerry
Re: Burnishing?
Post by Kerry » Fri May 10, 2019 5:32 pm
Found an original ad, my question answered, for running in the complete engine as well, neat tool wish I had one :cry:
HornsRus
First Name: Charley
Last Name: Shaver
Re: Burnishing?
Post by HornsRus » Fri May 10, 2019 8:21 pm
kerry i saved mine from the scrapman 30 years ago at an auction for $60.00.maybe you will get lucky to.charley
Randall strickland
First Name: Randall
Last Name: Strickland
Re: Burnishing?
Post by Randall strickland » Thu May 30, 2019 10:15 am
Not exactly burnishing but I do like to run in !
Bill Crosby
First Name: Bill
Last Name: Crosby
* REQUIRED* Type and Year of Model Ts owned: 1916 Touring, 1920 Coupe, 1926 RPU, 1927 RPU, 25 speedster project
Re: Burnishing?
Post by Bill Crosby » Thu May 30, 2019 6:13 pm
After I finish line boring I burnish the Bearings to the crank with time saver in the same setup.
Take a look @ www.youtube.com/watch?v=pJRMptqPNB4
