				How Can You Tell If Oil has Graphite in it?
				Posted: Thu May 09, 2019 2:22 pm
				by Bill Everett
				A common them in oil posts is to not use oil with graphite in it.
How can you tell if the oil you're thinking of using DOES have graphite in it?
				Re: How Can You Tell If Oil has Graphite in it?
				Posted: Thu May 09, 2019 2:31 pm
				by Philip
				im pretty sure if you stick with normal 10w30 valvolene penzoil ect you are good
				Posted: Thu May 09, 2019 2:32 pm
				It would be black as the ace of spades, and stain your hands. ARCO graphite oil is the only one I can recall in my life and that's gone from the market as far as I know. You'd have to specifically add it via an oil additive, which IS available...so the easy choice is: don't
				Posted: Thu May 09, 2019 2:51 pm
				Fairly safe your motor oil choices wouldn't have graphite.
But beware of greases, esp. if you use graphite containing greases in the u-joint.  Could get mixed with the engine oil, maybe such small qty. that wouldn't hurt the magneto, but why chance?
				Posted: Thu May 09, 2019 9:45 pm
				Read the label!
				Posted: Thu May 09, 2019 10:12 pm
				by Adam
				Any recent API certified oil will not have graphite in it.
