Hi,
what is the expected voltage on a 6V model T equipped with the Fun Projects Voltage Regulator (VR) and engine running at some rpms well above idle?
Voltage with Fun Projects VR
Topic author - Posts: 410
- First Name: Michael
- Last Name: Deichmann
- MTFCA Number: 29116
Ford Model T 1914 Touring
- First Name: Robert
- Last Name: Jablonski
- MTFCA Number: 407
Re: Voltage with Fun Projects VR
7.2 to 7.4 vdc
Thx, that wasalso as expected, but I only see 6,3 volts. Better check the generator.....
- MTFCA Number: 407
The reading that you're getting refleects the charge on your battery and the load. Same reading with your headlights on ???
- MTFCA Number: 52564
If you are checking the generator output on the generator side of the cutout, it should be read in amperes not volts and set for around 4-6 amps at medium fast idle. As said, if checking the output/battery side, that would be the battery voltage, there is line voltage at all times on that side.
1920 Dodge touring
1920 Dodge touring
