Voltage with Fun Projects VR
Posted: Tue May 16, 2023 4:31 pm
by dykker5502
Hi,
what is the expected voltage on a 6V model T equipped with the Fun Projects Voltage Regulator (VR) and engine running at some rpms well above idle?
Re: Voltage with Fun Projects VR
Posted: Tue May 16, 2023 5:00 pm
by Moxie26
7.2 to 7.4 vdc
Posted: Wed May 31, 2023 7:03 pm
by dykker5502
Thx, that wasalso as expected, but I only see 6,3 volts. Better check the generator.....
Posted: Wed May 31, 2023 8:19 pm
by Moxie26
The reading that you're getting refleects the charge on your battery and the load. Same reading with your headlights on ???
Posted: Fri Jun 02, 2023 3:43 pm
If you are checking the generator output on the generator side of the cutout, it should be read in amperes not volts and set for around 4-6 amps at medium fast idle. As said, if checking the output/battery side, that would be the battery voltage, there is line voltage at all times on that side.
