Exhaust gasket rings?
varmint
First Name: Vernon
Last Name: Worley
MTFCA Number: 49462
Post by varmint » Thu May 25, 2023 7:29 am
I read some years ago to save the rings from the exhaust/intake gaskets. So, I did.
But I don't know what to do with them as they...
1) look fragile,
2) only have a lip on one side,
3) lip fits into the head or the manifold but I don't know which way they go (air flow direction?)
Thanks for suggestions.
Vern
Vern (Vieux Carre)
First Name: Jeff
Last Name: Humble
* REQUIRED* Type and Year of Model Ts owned: 1926 Canadian built coupe, 1924 TT C-cab, survivor 1924 roadster
MTFCA Number: 28034
Board Member Since: 2006
Re: Exhaust gasket rings?
Post by Humblej » Thu May 25, 2023 8:17 am
Vern, there are several types of manifold gaskets, some have reusable gland rings, yours is not that type.
Last Name: Wrenn
MTFCA Number: 30701
MTFCI Number: 24033
Post by TWrenn » Thu May 25, 2023 8:49 am
Okay, here I go again! These fall in the "love em or hate em" category, but I love em. Bit pricey, sure, but at least for me, they WORK well.
https://www.snydersantiqueauto.com/prod ... &cat=41892
Rich P. Bingham
First Name: Rich
Last Name: Bingham
Post by Rich P. Bingham » Thu May 25, 2023 10:22 am
I believe those copper gasket rings are likely re-usable indefinitely. The gripe comes when an exhaust manifold is warped. They don't forgive that very well.
Glands with that profile used to be made of a light metal with an asbestos (?) core. They would crush a bit when tightened and would somewhat forgive some mis-alignment. Too bad they're no longer available.
Get a horse !
Post by Norman Kling » Thu May 25, 2023 10:35 am
I use the 4th one posted above called "Original" They are inexpensive. you can keep the glands and replace the copper rings. If the manifold is warped so they won't fit, you need to either straighten the manifold or replace it with a new one. That is the only way to keep the manifold from warping, because it tends to drop at the back where most of the heat is concentrated. Over the years it will stretch at the top and the back of the manifold will drop. Eventually it will get offset so much as to be impossible to seal. The flat gaskets will work for a while to seal the leak, but will not keep it from dropping. You could use the glands with the flat gasket which will keep it from bending, but they don't seal quite as well as the copper rings.
MTFCA Number: 16175
MTFCI Number: 14758
Post by Steve Jelf » Thu May 25, 2023 11:04 am
Norm's post is to the point, clear, and accurate.
While I don't doubt that the copper gaskets from Snyder's will work, they cost almost four times the price of the stock type which I find quite adequate. I like to help the gaskets seal with a bit of hi-temp RTV, especially if the block has any pitting around the ports.
https://www.modeltford.com/item/3063-64.aspx
Craig Leach
First Name: craig
Last Name: leach
MTFCA Number: 26647
Post by Craig Leach » Thu May 25, 2023 12:19 pm
Hi Vern,
I only use the paper gaskets on my speedster between the header flange & engine. I have had issues with them leaking even with the steel
glands. I do use them on the run stand if the manifolds are going to come right off after break-in. The glands are supose to keep the manifold
inline so it dosn't warp. I have not found this to be true in all cases. Test fit the manifolds with just the glands if they don't fit with just a good
bump with the palm of your hand or a soft hammer then the manifold is likely warped and will need to be straightened or replaced. With the
glands in place it can be a juggling act getting them all to go together. The steel & copper backed three hole gaskets work good but check to
make sure the glands fit in the holes ( found some don't ) The steel glands & copper rings seem to always work.
The claim is made that the solid copper upset gaskets keep the manifold inline. I would like to know if people have found this to be true.
Craig.
Sarikatime
Last Name: Seress
MTFCA Number: 27707
Post by Sarikatime » Thu May 25, 2023 1:24 pm
Why don’t you combine what Craig and Steve stated. Use the paper gasket with the high temperature RTV silicon.
I always get myself in trouble when I am thinking.
Post by Allan » Fri May 26, 2023 7:51 am
A model T exhaust manifold MUST be fitted with gland rings if it is to stay straight, and these need to be far more robust than the slit rings of sheet metal sold by the vendors.
With no gland rings, the manifold is free to "walk" against the face of the block. And it will, with every heat cycle it goes through, regardless of what kind of goo/sealant is used to make a "seal", and no matter what type of gasket is used. it may run for a while, but you'd better hope it stays straight.
The thick Cooper gland rings Snyder's sell act as gasket and gland ring in one piece. They are formed from material that is thick enough for you to file some lead-in to make for easier fitting. They are re-usable. If price is the problem, you could probably buy 3 sets for the same money direct from the manufacturers, Fuel Tank and Radiator Services in Queensland , Australia. Or you could just go on with the
same old same old.
Allan from down under
MTFCA Number: 51486
Post by TXGOAT2 » Fri May 26, 2023 8:07 am
Substantial gland rings combined with copper gaskets would give support and probably act to keep manifold temperatures down, which would prevent warping.
Adding some support for the exhaust pipe back toward the u-joint might also help.
Proper management of the fuel mixture and spark timing will make life easier for the exhaust manifold as well as the engine.
Running an engine with leaky exhaust manifold gaskets is hard on the manifold.
George Mills
Last Name: Mills
MTFCA Number: 29497
MTFCI Number: 10032
Post by George Mills » Fri May 26, 2023 9:38 am
The original picture shows the very early 3 in 1 bits and pieces....all done!
Yup...check for a straight manifold...warped ones don't do too good at sealing, and the new ones are about the cheapest investment you can make.
I use the steel sleeves and copper crush rings myself. Not overly frugal but just think those modern copper repurposed 'fittings' have a place...but not for me.
Clean out the counterbores in the block (if there are any left, use a dental pick or awl if you must)
Clean out the counterbores in the manifold.
Apply grease to the steel sleeve and 'stick' it to the manifold
Slide on the copper crush rings until flush
Using all 'three hands' set the manifold(s) in place.
Start down on the clamps until you feel the copper start to compress
Take another 1/2 turn and call it quits. The grease will burn off on about 5 minutes (others use RTV for the same purpose)
I for one do not reuse the copper crush rings on intake...just historically a waste of time in my book, I just keep a bag of copper rings around and if I don't get a seat on the intake (starter fluid test) I just redo from scratch, usually always get it the second time around.
I'm not a believer in those expensive ones (yet) as they too may be better as a once and done for the same reasons? Maybe fine on the exhaust? The intake could get expensive unless you sneak up on it? But that is not really an option unless you are willing to sneak up on the exhaust at the same time?
Post by Allan » Sun May 28, 2023 3:34 am
George perhaps I can persuade you to become an adoptee. A set of 6 of the one piece heavy copper rings costs approx US$17 directly from FTRS in Queensland. You could share a few sets with friends and still get them all sent for the one set of postage costs.
varmint
First Name: Vernon
Last Name: Worley
MTFCA Number: 49462
Post by varmint » Wed May 31, 2023 10:56 pm
Ok, thanks for all the replies.
I did not realize that those gaskets were paper when i bought them.
The fourth cylinder exhaust has dropped down about 1/4" to 5/16"...
and the threads at the pack nut were shot with only 3 turns remaining.
So, I bought a new exhaust manifold, and a set of original rings & glands.
It took three hands to install it today.
Vern (Vieux Carre)
Craig Leach
First Name: craig
Last Name: leach
MTFCA Number: 26647
Post by Craig Leach » Thu Jun 01, 2023 1:09 am
Hi Vern,
Only three hands, Dont pi$$ off the third hand thats good. Please don't get this wrong but what color green is that a model A color? Glad you
got it together.
Craig.
Post by Allan » Thu Jun 01, 2023 2:36 am
If "original" glands are the thin ships of folde sheet metal I would replace them with solid rings to protect that new manifold. They are only straight once. Look what happened to your original manifold.
varmint
First Name: Vernon
Last Name: Worley
MTFCA Number: 49462
Post by varmint » Sat Jun 03, 2023 1:15 am
Craig,
I tried to match the color that was already on the engine and transmission.
Maybe this is what the New Orleans assembly plant thought was drake green.
Allan,
I used this kit:
https://www.snydersantiqueauto.com/prod ... 81307&cat=
Do you think I should weld the ends together?
Vern (Vieux Carre)
Craig Leach
First Name: craig
Last Name: leach
MTFCA Number: 26647
Post by Craig Leach » Sat Jun 03, 2023 2:16 am
Hi Vernon,
My coment on the color was more in jest as I have seen T engines in every color in the rainbow. I incorrectly paint mine black, ford grey & cast
blast & black tappit cover & trans cover. That is just one I have not seen before on a T as far as I can remember. Allen is a perponent of solid rings
I have not tried that. I do know that if the timing & fuel mixture are off enough to turn the exhaust manifold red all bets are off when it comes
to keeping the manifold from warping. The solid rings of heaveier material may be a + but to my thinking the split & rolled rings may have been a
ease of assembly thing more than a design function. I'm sure someone has the documentation to proove me wrong and thats OK. I have taken D
shaped rings out of a manifold that was real warped so I dont think they deserve the credit they get. A well installed straight manifold with the
muffler supported as intended ( and not hanging on the exhaust pipe from the manifold) with proper timing & mixture will last a very long time.
The number one thing I like about model T's is the fact that they can be enjoyed for reasonable cost especially if you can do alot of the work
yourself, the people in the hobby are great & the public loves them. There is few things as much fun as going to the gas station to fill up the night before a tour and coming home 2 hours later after dozens of pictures with people & kids in your car and some laps around the parking lot with
someone that has never been in a car older than a 1996.
Craig.
Post by Allan » Sat Jun 03, 2023 11:56 pm
Vern, those are the thin rolled sheet metal glands. When a manifold is removed they can be in all sorts of mis-shape. A better ring can be cut with a chop saw from a length of exhaust tubing.
The heavy copper set of 6 Snyder's can be bought from the makers in Australia for around US$ 17.50 Buy a few sets for the same postage as one set and share the reduced cost with your mates.
varmint
First Name: Vernon
Last Name: Worley
MTFCA Number: 49462
Post by varmint » Tue Jun 20, 2023 11:13 pm
Craig,
I found a better sample of whatever the green it was and have no clue if it's original.
This photo is from when we bought it.
engine sample.jpg (29.74 KiB) Viewed 1294 times
Vern (Vieux Carre)
MTFCA Number: 16175
MTFCI Number: 14758
Post by Steve Jelf » Tue Jun 20, 2023 11:49 pm
No, it's not. This is an original 1927 cutaway on display at THF.
MTFCA Number: 24868
Post by Jerry VanOoteghem » Wed Jun 21, 2023 5:36 pm
Craig,
Is that paint or moss? :lol:
Post by Scott_Conger » Wed Jun 21, 2023 8:09 pm
I have no opinion on the originality of the paint, but I do know this: having been flooded in salt water and then allowed to molder, I doubt that any of us knows exactly what a particular paint or paint color would do under those circumstances.
NH Full Flow Float Valves
varmint
First Name: Vernon
Last Name: Worley
MTFCA Number: 49462
Post by varmint » Wed Jun 21, 2023 10:18 pm
Paint or Moss?
Really good question.
6 cover sample.jpg (71.29 KiB) Viewed 1067 times
Vern (Vieux Carre)
J1MGOLDEN
Last Name: Golden
MTFCA Number: 14294
MTFCI Number: 13562
Post by J1MGOLDEN » Thu Jun 22, 2023 7:49 pm
That color is close to some garden equipment made in China or overseas.
I had a 1927 Ford with about 6,000 miles on it and the original engine color matched the original Model A engine colors.
I have a can of paint that has all the items in it to make the color of my truck box, which is close to the engine color.
Susanne
First Name: Susanne
Last Name: Rohner
MTFCA Number: 464
Post by Susanne » Fri Jun 23, 2023 6:13 am
https://www.mtfca.com/phpBB3/download/f ... &mode=view
This is one of my favorite examples of Ford Engine ("Highland?") Green... it's awfully hard to say this isn't it, since it is an unmolested original (cutaway) motor from Ford... And it;s far more durable than the "carbon tinted asphaltum" which they washed over engines before...
