				TIMING TOOL
				Posted: Fri May 26, 2023 2:52 am
				by Professor Fate
				Is this tool labelled "B" sold by a retailer, or fabricated individually?
				Re: TIMING TOOL
				Posted: Fri May 26, 2023 3:06 am
				by Kerry
				It would have been quicker for you to check the vendors on line catalogs than post your question with photo's here. but to answer your question, Langs, $1.45
				Re: TIMING TOOL
				Posted: Fri May 26, 2023 5:45 am
				by GG Gregory
				This tool only works for FORD type roller timer’s.
				Re: TIMING TOOL
				Posted: Fri May 26, 2023 5:46 am
				by Professor Fate
				I'm running a New Day timer.
				Re: TIMING TOOL
				Posted: Fri May 26, 2023 6:38 am
				by TWrenn
				Professor Fate wrote: ↑Fri May 26, 2023 5:46 am
Just use the "9:30-3:30" crank pin method and you'll be fine. PM me if you're not familiar with it and I'll describe it to you. Gimme your cell number even and I will call you.
				Re: TIMING TOOL
				Posted: Fri May 26, 2023 9:02 am
				It's pretty easy. No special tool needed.
https://dauntlessgeezer.com/DG97.html
				Re: TIMING TOOL
				Posted: Fri May 26, 2023 9:11 am
				Different strokes for different folks.  Steve’s method works pretty good.
The tool shown is real similar to the one that could be homemade  in Tinkerin Tips  years ago.
				Re: TIMING TOOL
				Posted: Fri May 26, 2023 9:23 am
				by Oldav8tor
				New Day - great timer....just sayin'
				Re: TIMING TOOL
				Posted: Fri May 26, 2023 9:25 am
				by Professor Fate
				I'm a tool geek. I like to collect stuff.
I made something similar out if a paint stick using my other cars timer as a model. I'll grab a mix for you all when I go out to the shop shortly
				Re: TIMING TOOL
				Posted: Fri May 26, 2023 9:39 am
				by Humblej
				Beware, as others have stated, the Ford Service Manual timer gage the vendors sell is ONLY reliable when using a Ford timer and a Ford roller. Other timers have different internals, brushes, or different rollers.
				Re: TIMING TOOL
				Posted: Fri May 26, 2023 10:32 am
				by TWrenn
				John kuehn wrote: ↑Fri May 26, 2023 9:11 am
That's the "9:30-3:30" method I plan to talk to him about.
				Re: TIMING TOOL
				Posted: Fri May 26, 2023 10:41 am
				by Nv Bob
				This tool only works on stock roller timer
Best way is Crank ratchet pin is parallel to the ground this puts piston TDC half the time set and run  and fine tune as needed
				Re: TIMING TOOL
				Posted: Fri May 26, 2023 12:57 pm
				by Been Here Before
				As fate would have it --
Running a New day Timer...this may be helpful:
https://modeltfordfix.com/repairing-a-new-day-timer/
Putting the hobby back another 60 years (c).
				Re: TIMING TOOL
				Posted: Fri May 26, 2023 10:00 pm
				by Professor Fate
Here's a pic of my homemade timing tool from 2 yrs ago. It's a wood paint stick. I had never seen the picture in the manual until the other day. I used my other T to make this one pictured. Manual dimension is 2.5  inches from center of each hole. Mine is 2.75 in.
I get repeated hot starts and my car starts easy. Sunday I'll look at 330-930 pun location. Thanks to all for your help.
