Transmission pedal shafts
Posted: Fri May 26, 2023 7:49 pm
Replacing pedal shafts, the wort part is getting the pins out, the clutch pedal was loose on the shaft the pin came out easily the brake and reverse pedals is another story I had to use heat WD-40 and drill into the pins from both sides only then would the pins drive out with a punch. BTW I ended up bending the punch shaft
Using my 20 ton press worked beautifully to remove the shafts.
