What are these non Model T cotter pin things called
bmklawt
First Name: Bruce
Last Name: Klawiter
Post by bmklawt » Mon May 29, 2023 4:14 pm
I was changing the bearing on my Prius last week and they used these cotter pin looking things on the castle nuts and I thought they would be great to use on my 1927 Touring until I get the bugs worked out after rebuilding everything on this car, I cant find them because I cant figure out what there called, anybody know?
Re: What are these non Model T cotter pin things called
Post by Scott_Conger » Mon May 29, 2023 4:43 pm
"clip"
1983-2005 Toyota 9046814011 (90468-14011)
NH Full Flow Float Valves
MTFCA Number: 4838
MTFCI Number: 115
Post by DanTreace » Mon May 29, 2023 4:59 pm
Generic re-usable cotter pins, various sizes.
jiminbartow
Last Name: Patrick
MTFCA Number: 50126
Post by jiminbartow » Mon May 29, 2023 10:57 pm
Hairpin cotter pins
Kaiser
First Name: Leo
Last Name: van Stirum
Post by Kaiser » Tue May 30, 2023 1:58 pm
We called these hairpin like things 'Fokkerpin' or 'Fokkernadel' in German, it seems Anthony Fokker invented them.
You learn somethimg new every day :lol:
Leo van Stirum, Netherlands
Last Name: Juhl
MTFCA Number: 50297
MTFCI Number: 24810
Post by Oldav8tor » Tue May 30, 2023 2:02 pm
Actually, they're rather ingenious. Fokker died in 1939 so it is possible some of these found their way onto European Model T's.
Kaiser
First Name: Leo
Post by Kaiser » Tue May 30, 2023 2:10 pm
Yes they are great, and a staple part in aircraft since way back when, probably even before the "Great War" of 1914/18
First Name: Jeff
Last Name: Humble
* REQUIRED* Type and Year of Model Ts owned: 1926 Canadian built coupe, 1924 TT C-cab, survivor 1924 roadster
MTFCA Number: 28034
Board Member Since: 2006
Post by Humblej » Tue May 30, 2023 2:46 pm
Bruce, I would not recommend those as a cotter pin replacement on a model T.
Kaiser
First Name: Leo
Post by Kaiser » Tue May 30, 2023 2:54 pm
It might take to the air :o
Post by Scott_Conger » Tue May 30, 2023 2:55 pm
Jeff
I am curious as to why not use them?
that is precisely what Toyota is using them for
I would not use them due to their looks (because I am one of those reprehensible people who like their "T" to look like a "T"), but they are certainly serviceable, and they are designed for that purpose.
As I had mentioned earlier, it is a Toyota equivalent cotter pin; it isn't a random pin being misused...it has a part number; it works on modern cars with castle nuts...I can't see a problem but am always open to learning.
Post by TRDxB2 » Tue May 30, 2023 3:29 pm
There are other options Might be different sizes
