Bendix Cover Screws: Size?
Topic author - Posts: 2952
- MTFCA Number: 24868
A discussion came up at a Model T Tech Talk at the Piquette Plant. One guy stated the screws were 1/4-24, while another suggested they are 10-27. I'm leaning towards 10-27. We all know they're "special" of course. Anybody know for sure the size?
Re: Bendix Cover Screws: Size?
Neither, Jerry
they're 14-24 ASME Standard (with uncommonly small diameter heads)
NH Full Flow Float Valves
- Last Name: Mills
- MTFCA Number: 29497
- MTFCI Number: 10032
14-24
(Or as the late Ralph Ricks use to say….use an M6 x1…just enough drag to keep ‘em from backing out…and built in advantage of a hex key to get that 3 o’clock one! )
- First Name: William
- Last Name: Vanderburg
- MTFCA Number: 28382
When i monkey with my bendix cover, I leave the three o’clock one in placeGeorge Mills wrote: ↑Mon May 29, 2023 5:38 pm14-24
William L Vanderburg
1922 Center Door Sedan
- MTFCA Number: 16175
- MTFCI Number: 14758
Nobody asked, but I'll show how I get them started with a long screwdriver.
- First Name: Art
- Last Name: Mirtes
- MTFCA Number: 32489
- MTFCI Number: 24068
I use a screw driver that holds the screw. It has jaws on each side of the screw head.
Without that I would probably use a 6x1mm 10 mm long
Art Mirtes
Art Mirtes
Thanks all!!!
