What should I look for?
Topic author - Posts: 151
- First Name: Joshua
- Last Name: Powers
- * REQUIRED* Type and Year of Model Ts owned: 1922 Center Door Sedan
I am going in a few days to check out an old t that a guy pulled out of a barn. I am thinking about buying it but since it is pretty modified I wanted to ask what I should be looking at specifically and what might be red flags. The car was apparently built pretty early and was raced back in the day. I have heard it run and it sounds like it has a modified cam. It has a high compression head, oil pump mounted where generator was, don't know what has been done in the engine. It has an aftermarket transmission and it looks like the stock transmission has had low gear and reverse removed and now just functions as a clutch for the other trans. I know nothing about anything that is not stock (and just know enough about stock to get myself into trouble). I am interested in the car but don't want to get into something that I will regret. I wish there was more that I could tell about it but the old guy doesn't know about Ts and I haven't seen it in person yet, just a couple pictures and I did hear it run. If you have any pointers of things on a car like this to be looking for please let me know.
- First Name: craig
- Last Name: leach
- MTFCA Number: 26647
Re: What should I look for?
Hi Joshua,
Sounds like the car is a wildcard. Was it built as a race car as in one seat racer body or just a fast car. Does the Aux. trans have reverse in it?
Most important is what are you looking for? A tour car or a racer or parts for the collection. The clutch & trans brake set up is not uncomon
See Hank Lees ad " Gentalmans speedster" If it's just a good deal & you are between it & the scrappers. Let your conscience be your giude.
If you deside to back away let people know it maybe what someone else is looking for.
Craig.
Craig.
- Last Name: Powers
I wish I knew more about it to tell you. He did say that the transmission is a muncie. He only ran it for a minute and has no idea about the condition of the transmission. It is a stripped down racer; open wheels, nothing for comfort, it looks to be lowered as well. I thought about doing a little sympathetic work and building more of a speedster out of it but nothing to take away from its history. I am a little fearful because I just don't know what exactly was modified internally or how expensive repairing a non stock car like this would be. It does have some type of early aftermarket wire wheels, I think that they are 18 inch. Also, if I decided to sell it later is there any market for old racers? I know that the individual speed parts are reasonably valuable but I don't think that I could part out something that has managed to survive so long stored away and untouched. Maybe it was a winning car back in the day; no one is probably alive that remembers it racing.
I am always skeptical of cars described as such. If you discussed a price better bring 1 or better 2 other people with you. It could be a scam. You assume you heard it but you weren't next to it. If it is ligit and some kind of racer I would not modify it with a Syverson style speedster. It is likely more valuable in ts present configuraton. If you have picture you can post them in the discussion for identification.
- Last Name: Powers
I am going to see it on Thursday and I will try to get some good photos of it then.
Note that anything which is not stock might be hard to repair or replace. If it runs you can drive it as is, but it might be a good idea to try to find a stock engine and transmission and start rebuilding so that sometime in the future you can replace in your present car or possibly another. They tend to multiply like rabbits, so this might not be your first Model T. Show us some pictures of the body, and engine, transmission etc.
- First Name: craig
- Last Name: leach
Hi Joshua,
A Muncie should have a reverse. The bearings & bushings are available for them. Aftermarket wire wheels you need to look close at the spoke
ends & nipples for rust & cracks. Some period lowering is sketchy. If it wasn't all the way across the country it would have my intrest peeked.
Craig.
Craig.
