22 hood shelf, fender and radiator shell assembly questions
ElGranadaT
First Name: MARTIN
Last Name: SHERIDAN
* REQUIRED* Type and Year of Model Ts owned: 1922 Model T Touring
MTFCA Number: 51336
Post by ElGranadaT » Tue May 30, 2023 5:29 pm
Greetings all -
Today I'm struggling with the radiator mounts. I'm trying to find some cross section diagram or photos of how the radiator stud mount, springs, cups, radiator shell, hood shelf wood blocks, hood shelf and fenders all stack together in a 1922 (this one is a Touring) Any and all help is greatly appreciated
Thanks in advance
Marty
Re: 22 hood shelf, fender and radiator shell assembly questions
Post by Scott_Conger » Tue May 30, 2023 5:42 pm
NH Full Flow Float Valves
ElGranadaT
First Name: MARTIN
Last Name: SHERIDAN
MTFCA Number: 51336
Post by ElGranadaT » Tue May 30, 2023 7:01 pm
Thank you. I had seen that in my research - the question I guess I should of asked was what about the hood shelf, hood shelf blocks, and fender stack up? I can't find a good illustration of how those all fit together. I don't think they can stack up with the radiator spring caps- subassembly.
Post by Scott_Conger » Tue May 30, 2023 7:48 pm
frame, fender, block, shelf
has nothing to do with the radiator
the large hole at the front end of the shelf is for the wiring bushing and wiring to the headlight to go through
Hint: if you use (or make) the correct small OD washers, for your year car, you can preassemble the shelf, shelf blocks, latches, springs and hardware out of the car. Then drop the whole assembly down over the fender/frame and bolt into place.
Another hint: if using new wood blocks, spend time fitting, adjusting and possibly altering the angles of the hood latch holes until everything fits correctly.
ElGranadaT
First Name: MARTIN
Last Name: SHERIDAN
MTFCA Number: 51336
Post by ElGranadaT » Wed May 31, 2023 11:16 am
Thanks again !
Post by Scott_Conger » Wed May 31, 2023 11:30 am
You're welcome
hopefully you're fitting things before paint... ;)
have fun!
