Torpedo firewall bracket
Posted: Fri Jun 02, 2023 1:40 am
by AndreFordT
Hi All,
I am working on a 1911 Torpedo.
To do the job right I am looking for the firewall to frame bracket set.
In the parts catalog from Chaffin's Garage I found the part number for these brackets 3640/41T.
Since a few days I am trying to contact them for asking if they have them in stock but can't get an answer.
Maybe somebody out there can help me with that.
Andre
Belgium
Re: Torpedo firewall bracket
Posted: Fri Jun 02, 2023 10:02 am
by TWrenn
Just keep trying, they get pretty busy.
Posted: Fri Jun 02, 2023 10:21 pm
by SurfCityGene
Andre, Since you are calling from EU. I can get thru to Dave ask about the availability and relay back to you?
Check the timing of your calls. Let me know if I can help,,,
Posted: Fri Jun 02, 2023 11:54 pm
by AndreFordT
Please Gene,
If you can help it will be great.
Andre
Belgium
Posted: Sat Jun 03, 2023 2:50 am
by Andrew Brand
Hi Andre
I have an original pair (not for sale - for my Torpedo). If you can't get them and need dimensions to make them, I can help.
Andrew
Posted: Sat Jun 03, 2023 9:38 am
by AndreFordT
Yes Andrew,
It will be a great help if I had the dimmensions to make these brackets.
Selling yours should be easier, but ...
Have a fine day.
Andre
Belgium
Posted: Sat Jun 03, 2023 9:42 pm
by ahovey
Andre,
I responded to your post last year on this with a few dimensions.
https://www.mtfca.com/phpBB3/viewtopic.php?f=2&t=26704
Let me know if I can be of any other help with dimensions or anything else. I had detailed engineering drawings made for these brackets.
Austin
Posted: Sun Jun 04, 2023 2:42 pm
by AndreFordT
Thanks Austin,
I couldn't find this post.
Do you have other messurment about these brackets?
I think the only way to do this right is to make the brackets myself but there for I will need good drawings.
Andre
Belgium
Posted: Tue Jun 06, 2023 6:39 pm
by SurfCityGene
Andre, I just talked to Dave at Chaffins and he has ONE set of those brackets in stock. I'm not sure if you were using the New Number and allowed for the time difference? Chaffins new number is 1-951-226-7331, New address518 N Spring St Lake Elsinore, Ca. 92530
Hope this helps
Posted: Tue Jun 06, 2023 6:44 pm
by SurfCityGene
Andre
You might also email them at
support@chaffinsgarage.com Their hours are 8AM to 5PM Pacfic time Monday thru Friday
Posted: Wed Jun 07, 2023 9:22 am
by AndreFordT
Gene,
I just send a mail to Dave to order the brackets.
At This time I am in the South of France till next Monday and will try to get them on the phone.
Andre
Belgium
Posted: Mon Jun 12, 2023 10:34 am
by AndreFordT
Thanks All,
Parts are on the way to us.
Thanks Dave to help .
Andre
Belgium
