Terminal block
Topic author - Posts: 813
- First Name: William
- Last Name: Vanderburg
- MTFCA Number: 28382
Terminal block
On a wooden firewall, is the terminal block held to the firewall with the same screws that hold the wires? Or are there longer screws for that? Thanks!
William L Vanderburg
1922 Center Door Sedan
Re: Terminal block
All depends on what you have --Will_Vanderburg wrote: ↑Sun Jun 04, 2023 1:42 pmOn a wooden firewall, is the terminal block held to the firewall with the same screws that hold the wires? Or are there longer screws for that? Thanks!
Not sure about this being for both wood & steel firewalls.
- Last Name: hardiman
- * REQUIRED* Type and Year of Model Ts owned: 26 coupe
Re: Terminal block
Metal firewall! What size terminal block screws (original) are they?
- First Name: Ben
- Last Name: Austin
- MTFCA Number: 30480
Re: Terminal block
On my '22 it is held on by the screws that hold the wires.
