T electric horn wiring
Posted: Fri Jun 09, 2023 5:42 pm
by Bruce Compton
Does anyone have a diagram of the wiring inside the T horn. The one I have has had the wiring removed and the contact plate is just hanging in mid-air. Thanks in advance; Bruce
Re: T electric horn wiring
Posted: Fri Jun 09, 2023 6:21 pm
by varmint
I might have some photos of the inside but you need to specify whether you have a magneto horn or battery horn. A make, year, and model# of the horn will probably help too.
Posted: Fri Jun 09, 2023 6:28 pm
by varmint
app.php/gallery/image/2257
...if you have a magneto.
Posted: Fri Jun 09, 2023 6:53 pm
by Bruce Compton
Thanks Vernon but I have the later 6 VDC electric horn.
Posted: Fri Jun 09, 2023 8:24 pm
A picture of the horn internals would help.
Some 6v DC horns have one lead for the positive connection and the horn shell needs to be grounded.
If it has two posts for connection shouldn't matter which is + or - just which way sounds better
Posted: Fri Jun 09, 2023 11:20 pm
by BE_ZERO_BE
Here are some links to color Wiring Schematics and Wire Harness Diagrams.
Wiring Schematics
https://nebula.wsimg.com/3e10aca08d1115 ... oworigin=1
Wiring Harness Diagrams
https://nebula.wsimg.com/3a0733937917a1 ... oworigin=1
