TT Ton Truck Remove rear springs from frame
Posted: Wed May 15, 2019 10:03 pm
by chippy74@bigpond.com
Good morning,
I’m attempting to remove the springs from the rear of a TT Ton Truck and have removed the six 1-1/16 crown head nuts from there bolts, the triangular plates and the two U shaped shackles but have not been able to remove the bolts from the frame that run through from the end of each set of leaf springs.
Are they threaded in, are they pressed or maybe just extremely seized?
Any help greatly appreciated.
Re: TT Ton Truck Remove rear springs from frame
Posted: Wed May 15, 2019 10:15 pm
by D Stroud
Mathew, they are most likely rusted in tight. They can be a real bear sometimes. Then, the springs will be rusted in pretty tight probably. Dave
Posted: Wed May 15, 2019 10:22 pm
Thanks Dave I’ll keep working the mongrels.
Posted: Wed May 15, 2019 10:34 pm
Don't be surprised if you find one or more of the smallest spring leaves broken. Those trucks were often overloaded, so there are a lot of broken leaves.
Posted: Wed May 15, 2019 11:38 pm
by A Whiteman
I found I had to remove the clamp from the spring pack then chisel each leaf off one at a time....
Posted: Thu May 16, 2019 1:04 am
by HPetrino
When you tear into these darn old trucks you never know what you're going to find. When I took mine apart I found one top leaf broken and one missing altogether. What was really interesting was the fact that on the left side the pin bolt went through the top and bottom leaves but the rest were just stuck in there loose, with the bolt not passed through the leaf holes. I can't imagine what kept them from falling out. I'd sure like to know the story behind how that came to be.
Good luck with yours!
Posted: Thu May 16, 2019 2:46 am
Finally got them out, it was a battle but all the springs are in reasonable condition.
Thank you all for your replies.
