TT Rocky Mountain Brake Linkage
Posted: Tue Aug 01, 2023 11:47 am
by BUSHMIKE
Does anyone have a pic of the Rocky Mountain brake linkage? I would like to see pics of the ORIGINAL cable equalizer and attachments at the front end. Anyone have an original brochure of the TT Rocky installation instructions? Thank you.
Re: TT Rocky Mountain Brake Linkage
Posted: Tue Aug 01, 2023 12:05 pm
by Original Smith
I don't have a photo of the truck equalizer, but I do of the passenger car version. Since the brake pedal is the same perhaps the truck equalizer may be the same too?
Posted: Tue Aug 01, 2023 1:20 pm
by mtntee20
The equalizers on our TT and on our Delivery (car frame) trucks appear to be exactly the same unit, even though the brake manufacturers are different. I see no reason they should/would be different as they both connect to the emergency brake cross shaft the same way, in the same spot.
Good Luck,
Terry
Posted: Wed Aug 02, 2023 11:30 am
by Original Smith
Originals don't connect to the controller shaft. You must have something else. Keep in mind, originals use a cable, not rods.
Posted: Thu Aug 03, 2023 9:17 am
by BUSHMIKE
Still looking for a pic of how the Rocky Mountain brake cables connect in front…….
Posted: Thu Aug 03, 2023 9:31 am
by Scott_Conger
Surprised no one has actually led you to information...here it is, or at least a good deal toward what I THINK you're looking for: https://www.mtfca.com/discus/messages/1 ... 1321237805
Posted: Thu Aug 03, 2023 10:01 am
by Original Smith
Here is some photos of original real Rocky Mountain Brake linkage for passenger cars. I can submit lots more pictures if needed.
Posted: Thu Aug 03, 2023 10:07 am
by Original Smith
Here is the pedal clamp
Posted: Thu Aug 03, 2023 10:11 am
by Craig Leach
Hi Mike,
Because the frame is much taller on a TT the park brake shaft is lower than on a car in relation to the peddals. That may give you some
lever geometry issues. This sounds like a supplier support question.
Posted: Thu Aug 03, 2023 11:18 am
by BUSHMIKE
Thanx guys! Exactly what I was looking for. Being a TT, I know I will have to engineer some of linkage/ratio when the time comes.
Posted: Tue Sep 26, 2023 1:03 pm
by Tadpole
I am hijacking this old thread with another TT Rocky question. Does anyone know if you need longer hub bolts to mount the new repro Rocky kit for a TT truck? 1926 big drum of course, I don't think the kit came with any hub bolts.
Posted: Tue Sep 26, 2023 2:16 pm
by Mark Gregush
Yes maybe, as would add about 1/8" thickness to the original brake drum that would be install with it. The original bolts would have been just long enough to hold everything together after being peened or staked. But bottom line would be, you will have to look at what you have now to see. Most times I have removed peened nuts/bolts, they were not savable.
