Re-torque of RAJO head
Posted: Fri May 17, 2019 8:09 am
by rnkugel
I recently put the RAJO head back on the motor and ran it twice for about 15 minutes each (on jack stands) in the shop. My question is, when I go to re-torque the head bolts, should I do this cold or after allowing motor to come to temp? I'm going to 45 ft lbs as a final setting. Thanks
Re: Re-torque of RAJO head
Posted: Fri May 17, 2019 9:53 am
There will be other opinions BUT I run through at least 3 heating (block operating temperature) & cooling cycles and torque dead cold @45 lbs. - I also run a BB RAJO and did that same drill near 30 years ago on my Racer and haven't touched it since !
Posted: Fri May 17, 2019 10:49 am
by rnkugel
Thanks Steve. I will take your advise.
Posted: Fri May 17, 2019 5:33 pm
by Kerry
Re-torque cast iron heads hot and aluminium cold.
Posted: Sat May 18, 2019 6:03 pm
by D Stroud
Why would you re-torque cast iron heads hot. I'm by no means an expert, but I have been around and/or worked on everything from heavy equipment, hot rods and helicopters, in the last sixty years and I have NEVER heard of that being done. Makes no sense to me. JMHO Dave
Posted: Sat May 18, 2019 7:07 pm
by Kerry
Gasket sets usually have instructions to do so and like many spec/tech books also but with out giving the reason why.
The types of metal expansion rates, example, in older engine design of a cast iron block and steel bolts/studs, you have about 15% stretch on the bolt when getting up to operating temp, if not allowed for in a re-torque when hot then when cooled down then you have less torque on the gasket which gives the posibility to leak or blow the gasket prematurely.
Posted: Sat May 18, 2019 8:41 pm
That "might" be good information BUT clearly specific to "studs" - no way I'm pulling a 7/16" Model T head bolt to 55-60 lbs.
Posted: Sat May 18, 2019 9:01 pm
by Kerry
Steve,
Nothing clearly specific at all that it refers to studs, clearly reads bolts and as for the 7/16" at 55/60 is not a bolt problem on a T, we all know or should know it's the failure of the cast iron block that's the weak point, it strips well before a good 7/16" bolt breaks at 60lbs.
Posted: Sun May 19, 2019 12:04 pm
Sure appears that the chart you posted a photo of states "recommended bolt tensions" but just below under the size chart, it refers to "studs" - perhaps that might be a language difference between our English & yours ?
So, why would anyone pull a Model T head bolt to that torque ?
Posted: Sun May 19, 2019 6:09 pm
by Kerry
Yes you are right Steve, 100% in reference to what a head bolt or a stud is capable of. Shouldn't have used it in relation to a Model T :lol:
As for a model T, as far as I'm concerned, the tension wrench belongs on the tool board collecting dust. a ring spanner and ones feel is more than addequate. Cold then hot a couple of times, unless a Z head then then only cold a few times.
