I haven't put Scandinavian bands in a T in almost 20 years but I am going to soon, do folks still find that pre-soaking them in oil is the best method?
Thanks,
Jim
Scandinavian Bands soaking or not?
- First Name: Bob
- Last Name: Middleton
- * REQUIRED* Type and Year of Model Ts owned: 18 roadster 1810 brand X
Re: Scandinavian Bands soaking or not?
Jim
I used to now put them in dry
Add a quart of oil over them after installed
Never had an issue in 20 sets doing it this way
Oh dint drain extra oil out yhe top pet cock
- MTFCA Number: 14972
- MTFCI Number: 15411
I pre-soak for a couple days - everyone does what works for them.
- First Name: Jim, Sr.
- Last Name: Rodell
- * REQUIRED* Type and Year of Model Ts owned: 1922 coupe, 1926 touring
- MTFCA Number: 2406
- MTFCI Number: 22213
Put the bands in and close up the cover. Start the engine and let it idle for a while. With all that oil splashing around they will be soaked up quickly.
1922 Coupe , 1926 Touring
- First Name: Herman
- Last Name: Kohnke
- * REQUIRED* Type and Year of Model Ts owned: 1914 Roadster, 1922 Coupe
- Last Name: Hunter
- Board Member Since: 2002
I soak them in automatic transmission fluid. I have changed one lining without soaking successfully, but next time I changed it the rivets didn't want to go in as they should. Change of material perhaps? I soaked it and no problem.
