				brass tags
				Posted: Sat Sep 02, 2023 3:12 pm
				by Melba Nolan
				Can someone tell me what these brass tags are for.  They are round and oval with numbers on them.  Also on a steering shaft what is the difference between a round top and a triangle top. Couldn.t post picture.
				Re: brass tags
				Posted: Sat Sep 02, 2023 4:41 pm
				by Moxie26
				Looking at those tags with numbers, would they indicate a date like 321, that could match March of 2021?. Some of us who do rebuild things could put such a tag on a differential housing, steering column starter or generator, or even have numbers impressed into the wood of an ignition coil..... That would indicate when the item was rebuilt or refurbished.
				Re: brass tags
				Posted: Sat Sep 02, 2023 4:58 pm
				by Melba Nolan
				the oval tags are about 2" wide and about 1" 1/4 high.  some have.  some of the numbers are: 0 -  2 1/4   -  1/2  -2 1/4 -  1 3/4 -1  -  2  and the round ones are an inch in diameter with the number 2  and 150.  the 1.5 inch diameter has 544  and the others are blank
				Re: brass tags
				Posted: Sat Sep 02, 2023 5:08 pm
				Regarding the steering shaft - only round ones I've seen were the reproduction Texas T Parts - Ford had a triangular top.
				Re: brass tags
				Posted: Sat Sep 02, 2023 8:32 pm
				by Melba Nolan
				thanks for the info on steering.
				Re: brass tags
				Posted: Sun Sep 03, 2023 11:13 am
				How about some photos?
				Re: brass tags
				Posted: Sun Sep 03, 2023 5:39 pm
				by Melba Nolan
				couldn't post. can email or text
