Tire pressure, how low can I go?
Topic author - Posts: 761
- First Name: Thomas
- Last Name: Hicks
- * REQUIRED* Type and Year of Model Ts owned: '24 TT, '26 TT, '24 Speedster, '26 Speedster
- MTFCA Number: 32518
My speedster is lightweight and has a hard ride, bumps in the road can effect handling at higher speeds. The tires are Universal with balance beads and I had them filled to 45 lbs. I have been lowering the tire pressure and have found she rides much more smoothly at 20 lbs. Can I go any lower with the tire pressure?
- First Name: Dallas
- Last Name: Landers
- MTFCA Number: 49995
Re: Tire pressure, how low can I go?
I would guess that the lower pressure would let the tire slip on the rim and cause the valve stem to start leening which will wear the stem or pull it inside the rim. As to how low I cant answer. Good question Tom.
- MTFCA Number: 1219
21" are more forgiving than 30". You are asking for trouble at High speeds as Dallas explained.
How smooth is the wheel where the tire fits on it?
- First Name: Mike
- Last Name: Walker
- MTFCA Number: 314
Since you have 21" tires (as shown in your pic), you don't need so much pressure. I run 35 in mine, and it rides great. I switched from years of running clinchers to a set of 21" McLarens a few months ago, and I was quite surprised at the major difference in how well they ride with the lower pressure. The problems Dallas mentions are what you need to observe with clinchers, not balloon tires.
- MTFCA Number: 16175
- MTFCI Number: 14758
I think 20 psi is too low and is likely to cause damage. I agree with Mike on 35 psi for balloon tires.
- First Name: Adam
- Last Name: Doleshal
- MTFCA Number: 23809
- MTFCI Number: 1
- Last Name: Hicks
Smooth. The rims were new a few months ago.Rich Eagle wrote: ↑Sun May 19, 2019 9:13 am21" are more forgiving than 30". You are asking for trouble at High speeds as Dallas explained.
- Last Name: Hanlon
- MTFCA Number: 50191
While balloon tires run at lower pressure, I also believe damage to the tube/tire slipping on the rim, will occur with under inflation. It also adds heat.
Stick with the chart Adam posted and you'll be fine.
- First Name: Kevin
- Last Name: Pharis
On a light speedster, I have found that bout 25-30 psi burns thru the center tread section pretty quick. Down around 10-15 psi will even up the wear... but also provides inevitable complications such as tire slippage and slushy ride. Not worth the trade off!! I usually try for 20 psi (it’s not unusual to be down around 15... oops), but spend a bit of time switching the wheels from right to left side to keep the valve stems from getting too bent out of shape.
If you zoom in on this pic close enough, you’ll notice the valve stems are laying flat against the rims...
- MTFCA Number: 4838
- MTFCI Number: 115
Kevin
Good insight. IMO, have run 30-32psi in the '27 touring, it carries passengers most time. Tire wear hasn't been an issue, nor bent-over rubber stem.
Yours.....oh my....
Am just wondering if those big disc brakes on that nice speedster are having most of the impact of pulling your valve stems flat!
Yours.....oh my....
- First Name: Andrew
- Last Name: Clary
- MTFCA Number: 24057
Dan. If you notice the direction the stem leans, it is from the pull, not the braking. Kevin's speedster runs "ok".
Andy
Andy
- First Name: Dennis
- Last Name: Prince
- MTFCA Number: 22802
I have run 55 psi in my 21 inch tires for almost 50 years and never had a problem with tire wear and I found I could make a bigger difference in ride by lubing the springs often. My model A drives way better at 55 psi than 35 psi and the T's roll a lot better at the higher pressure. I run 525x21 tires on two of my T's and run 40 psi. Just my 2 cents.
- First Name: David
- Last Name: Stroud
- Board Member Since: 2011
If I'm not mistaken(and I may well be) the stems will be pulled the same direction by braking OR pulling. Dave
1925 mostly original coupe.
- First Name: David
- Last Name: Stroud
Nope, never mind. Finally got my brain to wrap around this. Dave
- First Name: Seth
- Last Name: Spratlin
- * REQUIRED* Type and Year of Model Ts owned: 1914 Speedster
Lol that valve stem lean means that Kevin just isn’t braking hard enough before the corners. A more aggressive speedster driver will pass him in the turns! (Just picking Kevin)
- First Name: Kevin
- Last Name: Pharis
One may not have noticed the front brakes in the pic... but I do have issues with the front stems too
- First Name: Gene
- Last Name: Carrothers
- MTFCA Number: 22905
- MTFCI Number: 23068
No expert on your tire pressures but to me it seems like 20 is really too low and the slip verifies it. Better a slightly bumpy ride than a tire problem. For the Montana 500 we run the Max pressure!! IMHOP
Hey, can you tell us more about those front disc brakes. Looks like the same on the back?
Gene
Period Four Wheel T Brakes
Gene
1912 Torpedo Roadster
- Last Name: Clary
As to the original question, I run 35 pounds on my 26 coupe (fairly heavy) and 30 on my speedster.
Andy
Andy
- First Name: gary
- Last Name: hammond
- * REQUIRED* Type and Year of Model Ts owned: 1926 roadster
My 2 cents worth....lol Any transverse spring vehicle is not inherently stable under fast or emergency maneuvers. An underinflated tire will contribute greatly to a high center- of- gravity, stiffly- suspended vehicle's tendency to roll over. These wheels are not safety beaded rims, they are smooth inside with no raised ridge to retain a underinflated tire on the rim. In a straight line go like the devil, but IF an unforeseen situation arises underinflated tires could end up with a very bad result.
''Just Passin' Thru.....Slowly!
- First Name: David
- Last Name: Stroud
I don't have any experience with tires on a speedster or other light car, but if my tires were slipping enough to bend the stems, I would for sure add some more pressure, regardless of the ride quality. JMHO Dave
- First Name: Mike
- Last Name: Walker
- MTFCA Number: 314
That chart posted by Adam D. is informative. Thanks, Adam. I assume it's from some of Ford's literature? Based upon the chart, it looks like I can reduce the pressure in my tires just a bit. I'll probably run them at 30 now. I'd rather err on the side of too high than too low. And as I said in my post above, even at 35 psi they ride 10 times better than what I've been accustomed to. One thing is for sure -- if you are seeing your valve stems lean, your pressure is too low for your car and your driving habits.
- First Name: Adam
- MTFCI Number: 1
Chart is from the Ford Manual.
- First Name: Alan
- Last Name: Long
Reading the official Ford Data on Tyre pressure I rounded the pressure up from 27 to 30 PSI on my 26 T however minor signs
of under inflation wear tell me that 32 or 35psi maybe the go. Forget how low you can run tyres at but how high which is a worry when you understand how crappy the new stuff is!!!
Alan
Alan
- First Name: Neil
- Last Name: Martin
- * REQUIRED* Type and Year of Model Ts owned: 11 tourer 18 tourer 18 TT
Alan,
I have 30x3.1/2 oversize Universal tyres on a 1913 Crossley 5 seat touring and I run 90/100 psi to stop the tyres turning on the rims and cutting off the valve stems. I run hard tyres and lubricated springs and have had no problems with ride and or tyres.
Warm Regards...Neil.
- First Name: Bill
- Last Name: Chuplis
If the ride and handling are still objectionable at 28 lbs, take a leaf out of the springs.
- First Name: Neil
- Last Name: Martin
NO, Just lubricate them.
