Cam nut wrench!
Posted: Mon Sep 11, 2023 7:52 pm
by Les Schubert
I’m wondering if there is a dozen people who would be interested in buying one. It’s a special “box end” with a 1/2” offset of the handle. Thinking about making some. They would be CNC cut and have about a 10” handle.
Re: Cam nut wrench!
Posted: Mon Sep 11, 2023 8:34 pm
by JTT3
I’m a fool for tools
Re: Cam nut wrench!
Posted: Mon Sep 11, 2023 8:53 pm
by Les Schubert
Thank you John
Re: Cam nut wrench!
Posted: Mon Sep 11, 2023 9:04 pm
by TLeroux
i will take one
tom leroux
Re: Cam nut wrench!
Posted: Mon Sep 11, 2023 10:32 pm
by JBog
I'm interested.
Re: Cam nut wrench!
Posted: Tue Sep 12, 2023 1:58 am
Les, the less offset in the handle the better. The original open end Ford wrench for the purpose has an offset of around one inch, so the tool easily cranks off the nut before the nut is brought to a reasonable tension. When I use mine, I have a sleeve to go over the cam snout to engage on the wrench end, a washer to blank off the outer end of the sleeve, and a spare timer nut to hold the wrench, sleeve and washer to stop the wrench crankoing off the cam nut.
Re: Cam nut wrench!
Posted: Tue Sep 12, 2023 7:28 am
by TrentB
Like every other Stevens tool I have ever run across, the T-138 Camshaft Nut Wrench works very well.
Respectfully submitted,
Trent
Re: Cam nut wrench!
Posted: Tue Sep 12, 2023 10:39 am
by AndyClary
I bought a cam nut socket from Snyder. It works good and also works quite well on the front wheel bearing.
Andy
Re: Cam nut wrench!
Posted: Tue Sep 12, 2023 10:53 am
by Glenn French
I am interested in one.
Glenn French
Re: Cam nut wrench!
Posted: Tue Sep 12, 2023 11:04 am
by Les Schubert
I will make one and post a picture and a price. Then you can decide.
The idea of using a spacer washer and a timer nut with it sounds like a good idea!
Re: Cam nut wrench!
Posted: Tue Sep 12, 2023 1:09 pm
A friend just uses a Model A spark plug wrench, bend in handle works ok. But a specialized tool would be likely best.
Re: Cam nut wrench!
Posted: Tue Sep 12, 2023 2:58 pm
by BE_ZERO_BE
A Snap-On 36-F socket is the correct tool.
Or one can be made from a front wheel bearing wrench
(cut from a hubcap wrench multi-tool),
a piece of tubing and an old socket.
Re: Cam nut wrench!
Posted: Tue Sep 12, 2023 3:56 pm
by Les Schubert
I am looking to make this into a double purpose tool.
One end will fit the cam nut AND the front wheel bearing. On the other end it will fit the front wheel bearing jam nut!
I think that they will probably cost about $20.00.
Re: Cam nut wrench!
Posted: Tue Sep 12, 2023 4:26 pm
by AndyClary
I made a front bearing socket out of a socket because you can’t use the ford wrench with buffalo hubs. I just milled a close enough form in the ratchet side since there’s no real torque on the bearing.
Andy
Re: Cam nut wrench!
Posted: Tue Sep 12, 2023 7:44 pm
by Tmooreheadf
I’d be interested in at least one maybe two!
Re: Cam nut wrench!
Posted: Tue Sep 12, 2023 9:00 pm
by Tmooreheadf
A couple of buddies want one so that’s two more for me! Total of 4.
Re: Cam nut wrench!
Posted: Tue Sep 12, 2023 9:14 pm
by South park zephyr
I would like one as well
Scott
Re: Cam nut wrench!
Posted: Tue Sep 12, 2023 9:37 pm
by Bob in ohio
I would like to purchase one.
Re: Cam nut wrench!
Posted: Wed Sep 13, 2023 10:30 am
by CDooREDW
I believe I’d throw in for one as well!
Thanks,
Ron in HSV
Re: Cam nut wrench!
Posted: Wed Sep 13, 2023 8:57 pm
by Randall strickland
I'll take one
Re: Cam nut wrench!
Posted: Mon Sep 18, 2023 5:32 pm
by Les Schubert
I picked up the cutout wrenches and now to bend them!!
Re: Cam nut wrench!
Posted: Mon Sep 18, 2023 6:12 pm
by Bill Anziani
I'm interested as well
Re: Cam nut wrench!
Posted: Mon Sep 18, 2023 7:22 pm
by OilyBill
I'll take one as well! Thanks!
Re: Cam nut wrench!
Posted: Mon Sep 18, 2023 7:42 pm
by Mike Lebsack-Iowa
Hi Les, I will take 3 of the wrenches. One for me and gifts for two good friends!! Mike Lebsack
Re: Cam nut wrench!
Posted: Mon Sep 18, 2023 11:31 pm
by havnfun
Hi Les,
The double purpose wrench sounds fantastic, I would like buy two
Re: Cam nut wrench!
Posted: Mon Sep 18, 2023 11:46 pm
by Randy SR
I will buy one as well, sounds like an awesome tool!
Re: Cam nut wrench!
Posted: Tue Sep 26, 2023 5:15 pm
by Les Schubert
The first one!
17 more soon!
Re: Cam nut wrench!
Posted: Tue Sep 26, 2023 5:18 pm
by Les Schubert
My “Guesstimate” on the cost was “OPTIMISTIC”!!
About $40.00!
Re: Cam nut wrench!
Posted: Wed Sep 27, 2023 9:22 am
Thanks, I am still down for 3 Les. Mike
Re: Cam nut wrench!
Posted: Wed Oct 04, 2023 12:53 pm
by Les Schubert
Update
Well I have 18 of these finished BUT now I find that while they fit most cam nuts perfectly I encountered one this morning that it won’t fit!! ARRGH!!
I’m not sure what to do!! I don’t want to sell something that doesn’t fit properly.
Re: Cam nut wrench!
Posted: Tue Nov 07, 2023 1:32 pm
by Les Schubert
I have now tested the wrench on 15 nuts (including a new repo one) and only one didn’t it fit. So if you are still interested I am prepared to sell them!!
Re: Cam nut wrench!
Posted: Tue Nov 07, 2023 2:06 pm
by havnfun
Les, I’ll honor my order of two, I sent you an email
Re: Cam nut wrench!
Posted: Tue Nov 07, 2023 2:14 pm
by South Park Zephyr
I’m good at $40 as well
Re: Cam nut wrench!
Posted: Tue Nov 07, 2023 4:40 pm
by Distagon2
Put me on the list for one. You can't have too many tools....
Re: Cam nut wrench!
Posted: Tue Nov 07, 2023 6:01 pm
by CDooREDW
Still in for one, Les. You can’t ever have too many tools.
Tnx,
Ron
Re: Cam nut wrench!
Posted: Wed Nov 08, 2023 10:14 am
by TLeroux
I WILL TAKE ONE AT NEW PRICE'
TOM
Re: Cam nut wrench!
Posted: Wed Nov 08, 2023 10:24 am
by Bob in ohio
I would still like to buy a wrench. Please post payment instructions.
Bob
Re: Cam nut wrench!
Posted: Wed Nov 08, 2023 5:40 pm
i'm still in
Re: Cam nut wrench!
Posted: Wed Nov 08, 2023 6:31 pm
by Bill Anziani
I'm still interested as well
Re: Cam nut wrench!
Posted: Thu Nov 09, 2023 8:04 pm
by Les Schubert
I live in Canada
To keep the shipping costs down I have bulk shipped a dozen wrenches to Mike Lebsack in Iowa. He should have them in about a week
Thank you all for your support and interest
Les
Re: Cam nut wrench!
Posted: Fri Nov 10, 2023 5:25 pm
by Glenn French
I am still in for one at the new price.
Glenn French
