Gallivan Head Gasket
Posted: Thu Sep 14, 2023 11:06 pm
by frontyboy
Does anyone have a photo or a pattern of a Gallivan head gasket? When I purchased "The Flying Dutchman" Gallivan powered 1915 model t roadster I got several new overhead gaskets but not sure if they are for the Gallivan.
A photo, or drawing would be very helpful. Also have a couple of questions regarding oil pressure and routing of oil lines.
thnx
frontyboy 2ho69191949(Seattle) fax or call
Re: Gallivan Head Gasket
Posted: Fri Sep 15, 2023 12:53 am
by pete eastwood
I would think that all overhead's would take the same gasket.
The gasket doesn't know if the head has rocker arms or cams!
Posted: Fri Sep 15, 2023 10:19 am
Posted: Fri Sep 15, 2023 10:24 am
by Kevin Pharis
Pete is absolutely correct. However, I suspect that your concern is that the combustion chamber is an odd shape and so requiring a special gasket, as is the case with a Roof 16 Model C. I would suspect that the Gallivan has a round combustion chamber. There is a lot more room for those giant valves when they are presented at an angle rather than straight down like a typical overhead. Isn’t there is a pic of the Gallivan combustion chamber in the Speed and Sport book…?
Posted: Sat Sep 16, 2023 4:15 pm
Olsons Gaskets, right up there in Washington state.
Posted: Sun Sep 17, 2023 9:34 am
by AndyClary
The ad in Speed and Sport shows a round chamber.
Andy
