License plate in the way of spare tire carrier.
Topic author - Posts: 913
- First Name: Ignacio
- Last Name: Valdes
- MTFCA Number: 50406
Hi, I have a spare tire carrier that mounts on the back but the license plate is in the way of one side of the mount. What is normally done in this situation to make it work? See the 2 mount holes on the right circled in red on the cross bar, there are 2 other mount holes on the left cross bar behind the license plate.
Re: License plate in the way of spare tire carrier.
The tail light and license plate are moved to center cross bar on the tire carrier.
This is where it goes. Mine is a roadster but same bracket used on touring.
- MTFCA Number: 4838
- MTFCI Number: 115
Illustration from Ford Service manual.
- MTFCA Number: 121
- MTFCI Number: 16310
With that riveted rear end, your car is too early for a spare tire carrier.
- First Name: Charley
- Last Name: Shaver
- * REQUIRED* Type and Year of Model Ts owned: 1913
while we are at it,if the frame has the holes in the cross member the frame is a latter one.charley
