				License plate in the way of spare tire carrier.
				Posted: Mon May 20, 2019 12:33 am
				by ivaldes1
				Hi, I have a spare tire carrier that mounts on the back but the license plate is in the way of one side of the mount. What is normally done in this situation to make it work? See the 2 mount holes on the right circled in red on the cross bar, there are 2 other mount holes on the left cross bar behind the license plate.
				Re: License plate in the way of spare tire carrier.
				Posted: Mon May 20, 2019 12:55 am
				The tail light and license plate are moved to center cross bar on the tire carrier.
				Posted: Mon May 20, 2019 1:01 am
This is where it goes.  Mine is a roadster but same bracket used on touring.
				Posted: Mon May 20, 2019 10:33 am
				Illustration from Ford Service manual.
				Posted: Mon May 20, 2019 11:02 am
				With that riveted rear end, your car is too early for a spare tire carrier.
				Posted: Mon May 20, 2019 12:20 pm
				by HornsRus
				while we are at it,if the frame has the holes in the cross member the frame is a latter one.charley
