1912 Heinze coils
Posted: Tue Sep 19, 2023 11:35 am
by rnwilliams
Could someone please share with me the dimensions of a 1912 Heinze coil w x d x h and the dimensions of the inside of an original Heinze coil box. I have a coil box that appears to be a reproduction Heinze box with no coils. Just not sure if it was made for Heinze coils to fit in. I know the contacts for a ford or KW coil does not line up. Thanks for the help.
Re: 1912 Heinze coils
Posted: Wed Sep 20, 2023 2:20 pm
by michaelb2296
2-5/16” X 3-1/16” X 5”
Spool is 2” X 3-7/8” - 8 sections. 5/16” wide. With 7/8” hole down middle.
Wood is 1/4” thick on each side except where it goes down to
1/8” thick where the coil resides.
Posted: Wed Sep 20, 2023 3:12 pm
by rnwilliams
Thank you Michael for taking the time.
Posted: Wed Sep 20, 2023 3:24 pm
by michaelb2296
You’re Welcome! As you can see they drilled the column for the coil after the box was assembled. They didnt drill all the way through either! They stopped about 1/2” shy of the bottom!
Notice the lip!
Posted: Sun Sep 24, 2023 11:17 am
by Bill Everett
E-mail with photos sent on 9-21-23.
