Rocky Mountain brakes for Pasco wire wheels
Posted: Wed Nov 22, 2023 5:37 pm
by AndyO
Hi Folks
Has anybody a method to install Rocky Mountain brakes or something similar for my speedster which has small drums and Pasco wire wheels. ?
The small drums were relined but are not good for much except as an E brake. Thanks Andy .
Re: Rocky Mountain brakes for Pasco wire wheels
Posted: Thu Nov 23, 2023 1:15 am
by Craig Leach
Hi Andy,
Most brake verses wheel issues can be solved by spacing the wheels out to get the needed clearance. Best I recall Pasco wheels bolt to the wire
wheel bolt pattern so spacers may be had on line. & you will need bolts to accommodate the spacing. Keep in mind that spacing the wheels out
will add stress to the wheel bearings & axles so be diligent with those parts.
Craig.
Posted: Thu Nov 23, 2023 11:30 am
by AndyClary
Your Pasco wheels will work just fine with accessory brakes. Bear end mind that the hub bolts are specifically for the Pasco wheel as the both secure the hub/drum but are also the drive pins. If stacking the second drum for the Rockies your bolts will probably be too short. In a speedster or roadster I’d probably stick to a small drum AC brake. If you need to replace your hub bolts you’ll probably have to have some made. I recommend contacting Kevin Pharis about that.
Andy
Posted: Thu Nov 23, 2023 1:43 pm
by AndyO
Hi thanks Are AC brakes still available ?
Posted: Thu Nov 23, 2023 7:47 pm
by AndyClary
There’s a current AC brakes thread with the new makers contact info.
Andy
