Stevens T-180 Generator Gear Puller
Posted: Thu Dec 07, 2023 8:15 pm
by namdc3
I picked up this puller, which is missing the stand and handle/punch. Could anyone with a good one measure exact dimensions of the punch so that I get it right? Thank you.
Re: Stevens T-180 Generator Gear Puller
Posted: Thu Dec 07, 2023 10:17 pm
I've been collecting Stevens tools for 30 + years - never have had the pleasure of finding the Stevens stand - I have a copy of the Allen holder. I have the puller & will measure my handle for you.
Posted: Thu Dec 07, 2023 10:44 pm
by namdc3
Thanks! It doesn’t look like there is a handle/punch in the one in the box either! Out of curiosity, what tool has the Hassler arm been turned into?
Posted: Fri Dec 08, 2023 10:59 am
The handle's in the top tray - I turned the Hassler arm into a peining jig for the gear pin.
Posted: Fri Dec 08, 2023 4:03 pm
Mine measures 0.310 in diameter - 4.50" in length - knurling is 1/2" wide & 2" from either end.
Posted: Fri Dec 08, 2023 5:12 pm
by namdc3
Thanks, that’s interesting. The one in the catalog has a punch for the gear pin built in. Maybe they figured out this was a clumsy setup, or maybe yours lost its original too. My handle hole is 5/16”. There is a square dent like some locknuts have, presumably to create an interference fit for the punch.
Posted: Fri Dec 08, 2023 5:14 pm
by Ed Fuller
Wow Steve! You have all of the coolest toys….I mean tools!
Posted: Fri Dec 08, 2023 5:25 pm
by namdc3
Here’s the only one I found online, and it appears to have the reduced-diameter punch part broken off at right.
Posted: Fri Dec 08, 2023 6:12 pm
by JH1427
When I picked up mine, it was also missing the punch. Had I seen this ad first, I would have better understood that it did not need a handle. A post with a picture and some dimensions would be great if anyone has the punch. J
Posted: Fri Dec 08, 2023 7:33 pm
I did not notice the "punch" end in the catalog illustration - I'll look mine over again but ?
Posted: Fri Dec 08, 2023 7:51 pm
by TrentB
This is a NOS Stevens T-180 I found at Hershey this year:
Respectfully Submitted,
TrentB
Posted: Fri Dec 08, 2023 8:04 pm
by namdc3
Wow! Could you give us the two diameters and two lengths?
Posted: Fri Dec 08, 2023 8:44 pm
Nice score Trent !!! First Stevens base I've seen.
Posted: Fri Dec 08, 2023 8:49 pm
by TrentB
Certainly.
The overall length is 5.525 inches.
The major diameter is .328 and is about 4.440 inches long.
The minor diameter is .162 and about 1.112 inches long.
The lengths of the major and minor diameters do not quite add up to 5.525 inches because of the transition from the minor to major diameters.
TrentB
Posted: Fri Dec 08, 2023 8:56 pm
by namdc3
Thanks! That’s really helpful.
Posted: Fri Dec 08, 2023 10:43 pm
Trent - is the handle/pin driver removable from the body ?
Posted: Fri Dec 08, 2023 11:03 pm
by KeithG
Trent, You lucky dog!!!!
Keith
