Distance from crankshaft to camshaft
Posted: Tue Dec 12, 2023 1:16 pm
by Dave1
Anyone recall the centre to centre distance from the camshaft to crankshaft?
Dave
Re: Distance from crankshaft to camshaft
Posted: Tue Dec 12, 2023 2:40 pm
by JTT3
3.9375 I believe is the number you’re looking for.
Posted: Tue Dec 12, 2023 3:20 pm
by Dan McEachern
that is correct.
Posted: Tue Dec 12, 2023 4:06 pm
by Steve Hughes
Otherwise known as 100 mm.
Posted: Tue Dec 12, 2023 6:11 pm
by Les Schubert
Steve is Correct!!
Posted: Tue Dec 12, 2023 7:02 pm
by Les Schubert
20-30 years ago I was trying to figure out what the correct gear spacing was. I had a perfect set of early straight cut gears and upon studying them I realized that they were essentially metric pitch gears and then the numbers worked out. I made some links to use for setting up my line boring and I got perfect gear mesh every time. No more need for off size cam gears!
Posted: Tue Dec 12, 2023 10:43 pm
by Dan McEachern
"I read it on the internet, it must be true".
