transmission questions
Posted: Tue Dec 12, 2023 4:08 pm
Happy holidays all!
After 3 and a half years my 22 Touring barn find restoration project is finally on filed trials!
Here's my problem - and some of this may be band adjustments and 'pilot error'... i.e. I'm teaching myself how to drive one by way of Youtube videos.
Reverse is fine - and from dead stop to low gear moving forward its nice and smooth - no grinding or chattering... (although I haven't go to very hi speed in reverse)
Once in forward motion I push the brake lever from center (neutral) to full forward, and when lifting my foot, the transition from low to neutral fine - but I may have that linkage from the brake handle to the clutch pedal off -since hi gear only seems to engage when the pedal is very near the top.
When shifting from low to hi, I throttle back to low rpm and lift the pedal, and from neutral to hi I get VIOLENT gear chattering that shakes the car... I chug through that- and it eventually smooths out somewhat but I've got a LOUD gear chatter while in hi and from under the floorboard...
This loud noise progresses to top speed on an open country road - but if I drop to say 700 to 900 rpm in hi its not too awful.
Now I tore the engine torn down to the block, and in the overhaul process we replaced a cracked drum and installed all new bands - All planetary gears looked very good - The engine also has new pistons- and runs fine.
I will need to pull the floorboards and adjust the brake in the next day or two - and plan to do a flex camera view of all - in the meantime,
what would the usual subjects be for this type of problem?
1 Just a bad driver? do you POP the pedal from low to hi? I tend to ease it out and in ---
2 Band adjustment?
3 Brake handle to trans linkage adjustment?
4 Rear differential issues? (saw this in a different thread) The rear differential is the ONLY thing I haven't reworked on this car...
(Murphy's law seems alive and well in this ol' gal... and I would not be surprised if that could cause it - but all the noise is from the trans)
any and all help and suggestions is always appreciated!
2 Band adjustment?
