What are these called? Available?
Posted: Sat May 25, 2019 12:38 pm
by Bobbbenner
Below find two pictures of interior metal work on either side of the cab on the floor. What are they called where can I get them. They are in a model TT
Re: What are these called? Available?
Posted: Sat May 25, 2019 1:05 pm
by CudaMan
These are close, but appear to be missing the tabs for holding the footwell trim panels. Did TTs even have footwell trim panels?
https://www.modeltford.com/item/STT209.aspx
Posted: Sat May 25, 2019 1:24 pm
by Les Schubert
You have a excellent example. Making a fix for the rusted side should only be 1-2 hours work would be a good learning experience. Properly done the repairs would be invisible
Posted: Sat May 25, 2019 1:42 pm
by Rich Eagle
I believe those are the floorboard risers for a '24-'25 Coupe or Tudor. Part No.s 17354X and 17355X. There are many around among closed car restorers. Some even have the vehicle identification number stamped into them.
Posted: Sun May 26, 2019 11:07 am
1925 open cars have those tabs too. They don't usually need bending.
Posted: Sun May 26, 2019 9:10 pm
by George House
Bob,
Are those floorboard risers on a TT Enclosed Cab ? I looked into my TT C Cab and the floorboard risers were different than your pics. I have a pair hanging in the barn but I’m afraid they’re for an open T. But I do believe the previous advice is correct. It should be a fun few hours with a minimum of metal working tools to repair these examples.
Posted: Sun May 26, 2019 9:34 pm
by Marv K
-Bob-
From memory on our TT, those look just like the 'toe-riser' panels where the sections of floorboards fit in. Our floorboards are also complete originals. I've not needed to replace, so don't know if there is a vendor who has them. If you need pictures, I can go to the shop tomorrow and send pics to you.
Posted: Mon May 27, 2019 11:51 am
by Rich Eagle
For those not convinced or that haven't seen one, this is a '24-'25 Coupe or Tudor. Part No 17355X as mentioned earlier. That is exactly what that cowl is and not a TT cowl. A cut-off Coupe or Sedan.
Posted: Fri May 31, 2019 11:49 am
by mvweaver
I agree, It's not a TT cowl because they don't have wood trim around the inside of the door opening. It's all steel.
