Maximum diameter of the main bearing cavities
Posted: Mon Dec 18, 2023 6:57 pm
by Dave1
Wondering how far can you bore out the main bearing saddles, on not effect the process of pouring Babbitt?
The concern is if you expose the bolt holes the molten Babbitt will leak out
Re: Maximum diameter of the main bearing cavities
Posted: Mon Dec 18, 2023 7:26 pm
by Mark Gregush
When the Model A crank is used, you do cut into the top bolt holes just a little. When babbitt is poured, the bolt or locating pins will block most of the hole so only a little babbitt will get in. After the mold is removed, that can be drilled out. If needed, the putty used for blocking and damming when pouring babbitt could be used as needed.
Posted: Mon Dec 18, 2023 9:16 pm
by Erik Barrett
What Mark said. For a stroker crank job you have to hog the T block all the way out to the bolt holes. Before pouring I plug the holes up to prevent leaks.
Posted: Mon Dec 18, 2023 9:35 pm
by Dave1
Thanks for the tips
Posted: Mon Dec 18, 2023 10:56 pm
by Kerry
Just the smallest of a hole will run hot babbitt like a river, the best plug I've found is house hold aluminium foil in the oil holes and exhaust sealer around the out side of the molds.
Posted: Mon Dec 18, 2023 11:27 pm
by Dave1
Kerry,
Aluminum foil I will have, exhaust sealer are you referring to header wrap or gasket material?
Dave
Posted: Tue Dec 19, 2023 2:17 am
by Kerry
Dav
I use a high temp paste made in Newzealand by CRC, it seals hard as soon as I heat the block saddles, caps or rods with a 1" propane torch before poring babbitt.
/attachment]
Posted: Tue Dec 19, 2023 11:01 am
by Dave1
Thanks Kerry,
This will be my first crack at pouring Babbitt, thanks for the tips
Posted: Tue Dec 19, 2023 12:16 pm
by Mark Gregush
I have been using/doing the same as Kerry, but different brand.
Posted: Tue Dec 19, 2023 1:44 pm
by Dave1
Mark,
Which brand do you use?
Posted: Wed Dec 20, 2023 1:32 am
by Mark Gregush
Adding new post to bump up.
Posted: Wed Dec 20, 2023 11:08 pm
by Mark Gregush
Permatex Muffler & Tailpipe Sealer #80335
Not sure if water base or not, the package does not say, it is water cleanup. I found best is to make sure it is fully dried before pouring the babbitt.
Posted: Thu Dec 21, 2023 2:31 pm
by Dave1
Thanks Mark
